'89 316i E30 LS1 Swap Build Thread
  • Q8y_drifter
    • Aug 2009
    • 297
    Hey everyone!
    I currently have an 1989 Alpine White 316i coupe with an RB25DET swapped into it. Purchased the car a couple years back with a blown RB25DET already swapped in. Decided to buy it, replace the RB with a new one from the scrap yard and beat on it.
    Well I had no idea what I got myself into and ended up having to fix a TON of issues along the way. Fast forward to a week back when, on an impluse, I said fuck it and decided to just yank all the RB engine/trans parts out and stuff an LS1/T56 in there.
    This will be the thread to document my build. The donor car is a base model E30 with drum rear brakes, 168mm 3.91 LSD, roll up/down windows and pretty much as base (read light) a model can get. I plan on listing out every purchase I make along with prices I paid so members can get a clue on what swaps like these end up costing.
    Found an LS1 from a Chevy Caprice at the junk yard. Picked it up for around $850.
    Alpine White 1989 E30 Coupe - LS1/T56
  • CLM21
    • Dec 2013
    • 223
    Nice! There's a lot of ls swaps going on right now....
    • jksmith
      • Feb 2015
      • 17
      will follow working on same build, almost exactly
      • shiboujin
        • Feb 2006
        • 2791
        What swap kit?
        • Q8y_drifter
          • Aug 2009
          • 297
          Originally posted by shiboujin
          What swap kit?
          Sikky.
          1-3/4" headers, Sikky steering shaft, steel driveshaft, stock LS1 with all new bearings, gaskets, hardware and a nice mild cam kit
          • shiboujin
            • Feb 2006
            • 2791
            Niiiice. Makes for an easy peasy swap!
            • Q8y_drifter
              • Aug 2009
              • 297
              Got my 241 heads back from the machine shop. Cleaned up, resurfaced and checked over. Got a ton of parts as well, taking pics of those later on.
              • DER E30
                • Sep 2013
                • 2349
                Watching intently...
                -Christian
                '37 Chevy pickup, the Ă¼ber project
                • Q8y_drifter
                  • Aug 2009
                  • 297
                  ARP main studs & bolts
                  Clevite H-Series standard size main bearings
                  LS1 bare block cleaned up. Dura-Bond single piece cam bearings installed
                  Cylinders honed
                  Main bearing clearance checked. All within 0.0015-0.0020in. Stock crank with polished journals and new lower cam sprocket.
                  Crank installed and ready for pistons and rods.
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    What are your plans for the rest of the components?
                    • Q8y_drifter
                      • Aug 2009
                      • 297
                      Not much really. Just looking to refresh this engine and upgrade some parts if needed. ARP bolts/studs where necessary, all new bearings, all new gaskets and seals, a nice mild cam for a bump in power and component upgrades where reliability may be a concern. Stock T56 if i can just get my hands on one. Rest of the car is already sitting on all new bushings, suspension, Z3 rack swap, etc. Will need a 188mm diff and stronger axles though. Will post more once parts come in.
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        Sikky swap kit. Went with 1-3/4" headers, steel driveshaft and Sikky steering shaft.
                        Stock rockers upgraded with Comp Cam trunions
                        • 1991 e30 bmw 318is
                          • 523
                          sick lookin gear! i wish i knew if the headers would fit my set up... o well just order pipe to finish building mine.
                          91 e30 318is M50 SOLD
                          http://www.r3vlimited.com/board/showthread.php?t=149570
                          92 325 vert project
                          http://www.r3vlimited.com/board/showthread.php?t=341370
                          • bmk
                            • Feb 2011
                            • 598
                            Those headers are gorgeous. I think mine are robbing some serious power stupid 1 5/8 Grr.
                            Worlds 1st LS powered e30 cabby.
                            Cab
                            billac: 92 LagunengrĂ¼n cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                            Raphael: 88 LagunengrĂ¼n IX + Hella 500's + Red ACS type 1's
                            Shaggin Wagon
                            : 01 325xiT 5 speed
                            91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                            88 CRX OEM+ 42mpg DD.
                            • shiboujin
                              • Feb 2006
                              • 2791
                              Damn. you got a nice camera lol.
