'89 316i E30 LS1 Swap Build Thread
  • DER E30
    • Sep 2013
    • 2349
    #46
    Any updates???
    -Christian
    • Q8y_drifter
      • Aug 2009
      • 297
      #47
      Yeah sorry about that I've been meaning to update this thread since forever.
      So far I've installed
      - Remote oil filter setup with modified hoses and fittings
      - All new SS braided power steering lines
      - Radiator/hoses/fan/overflow
      - Intake pipe and filter
      - All the brake and clutch reservoirs and hoses
      - All new 3/8" steel fuel tubing and hoses with a new 255lph walbro in-tank pump and rerouted the vent line to the gas cap.
      - Reinstalled the dashboard with all the gauges, ignition switch panel and kill switch wired up
      - Wired up 95% of the engine and ECU harness. Finishing up the fuel pump and fan relays
      - Relocated the battery to the trunk (stock was mounted upfront)
      I'm hoping I can get all the electrics done by tomorrow and hopefully have the ECU unlocked and ready before the weekend for its first start up.
      I did discover a major leak from the clutch slave which will require me to pull the transmission out though. That's gonna be a major PITA.
      The pic below is all I have for now I'll get updated pics tomorrow.
      Alpine White 1989 E30 Coupe - LS1/T56
      • DER E30
        • Sep 2013
        • 2349
        #48
        That sucks! I had the same thing happen during my truck build. Had to pull the cab and basically blow the whole thing apart to get at it ugh.
        -Christian
        • Gas Gang Racing
          • Jan 2016
          • 7
          #49
          sub'd currently doing the same swap in my 89 325is, im using the sikky kit as well but i will be going with the sikky hydroboost setup. we'll see how it goes!
          • Reyhan335
            • Nov 2015
            • 700
            #50
            subb'd looking good man. doing the same project
            e30Ls1 Swap IG: 1dirty30
            • stuff&things
              • Jan 2016
              • 2
              #51
              I am also doing the same project. Looks great bud, keep it up!
              • Q8y_drifter
                • Aug 2009
                • 297
                #52
                First start up video
                • Reyhan335
                  • Nov 2015
                  • 700
                  #53
                  Oh wow. More pictures! How was wiring man?
                  • Q8y_drifter
                    • Aug 2009
                    • 297
                    #54
                    Real easy. Buy a standalone harness. Read instructions. Wire it up. Start it up.
                    • Reyhan335
                      • Nov 2015
                      • 700
                      #55
                      What website did you get your harness from. Do you remember how much it was
                      • Q8y_drifter
                        • Aug 2009
                        • 297
                        #56
                        Looking to do an LS Swap? PSI is Your Source For LSX Conversion Parts. PSI sells affordable, in stock, full tech support, plug and play standalone wiring
                        I don't remember but it was just a bit more over the advertised price since I needed a couple different connectors wired up.
                        • Q8y_drifter
                          • Aug 2009
                          • 297
                          #57
                          • Q8y_drifter
                            • Aug 2009
                            • 297
                            #58
                            Still got a ton of cleaning and tidying up to do but it starts and idles so that's good.
                            • shiboujin
                              • Feb 2006
                              • 2791
                              #59
                              No vids? Boo. Build is looking super fresh man.
                              • Q8y_drifter
                                • Aug 2009
                                • 297
                                #60
                                Start up video posted a couple days back
