M60 barely runs when cold, 1,300rpm idle..
  • Jack89i
    • Dec 2013
    • 240
    So on cold starts it idles around ~700 but almost dies when given any throttle until it warms up. However, when its warm it runs great but idles at ~1300. No, there arent any vacuum leaks. I have replaced every gasket and smoke tested it. I was really thinking DME coolant temp sensor but resistance figures seem to be correct. Gas mileage is shit too. Im out of ideas.. anyone have any insight?
    sigpic'89 325i
    M60 swap in progress
  • JGood
    • Jan 2004
    • 7959
    Any codes?
    Stuck ICV?
    Does the TPS test good?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • sticksdaman
      • Apr 2005
      • 2987
      clogged fuel filter?
      Originally posted by ebelements
      Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
      • Jack89i
        • Dec 2013
        • 240
        Fuel filter is newish. But that wouldn't explain the high idle. Justin, my CeL has just always been on due to my lack of a char coal canister. Can't get the stomp test to work. I tested the tps a while back and all was well. What's wierd is I can get it to idle at 700 if I unplug and plug in the icv real quick while it's running. When I plug it back in it idles perfect at 700 for about ten seconds and then just jumps back up to 1300
        sigpic'89 325i
        • JGood
          • Jan 2004
          • 7959
          A Peake code reader is WELL worth the small investment.
          You can test the ICV, beyond making sure the valve isn't stuck (should hear a clicking when you shake it). You can test resistance between terminals.
          Terminals 1 & 2: 20 +/- 5 ohms
          Terminals 2 & 3: 20 +/- 5 ohms
          Terminals 1 & 3: 40 +/- 5 ohms
          • Jack89i
            • Dec 2013
            • 240
            Just tested the tps and it went from 1.6k closed to 4.47k wide open. I'll check the iac now
            sigpic'89 325i
            • dirty30
              • 3097
              check your throttle stop, make sure it isn't holding the throttle slightly open... I've seen this on an E36 before... different motor I know but same symptoms.
              • Jack89i
                • Dec 2013
                • 240
                Throttle stop is good. I pulled codes and got one for the lack of a char coal canister and one that said "CAN message"
                sigpic'89 325i
                • Jack89i
                  • Dec 2013
                  • 240
                  Also, it is to my understanding that with an auto harness I don't need to modify anything. I just chopped off the extra plugs. But..I'm using an auto dme..do I need to have a chip from a manual in there or does it not matter? I have no evap stuff just the vent line with a filter on it. Would I need to put a resistor or ground something out on the purge valve connector?
                  sigpic'89 325i
                  • JGood
                    • Jan 2004
                    • 7959
                    Nope, I actually just got done verifying all of that myself. Plug the throttle body inlet and vent the tank, that's what I've been running the past 3 years. Leave the purge valve unplugged. I just installed the entire system to see if it would change anything on my car, it did nothing but turn off the CEL, so I removed it all again.
                    The unmodified auto harness works as well. I installed one on my car a few years ago temporarily, and it made no change to anything. My spare DME is a stock auto DME, it runs perfect with it installed.
