Firing on all 8. checked my spark plugs, they smell like old gas... draining the tank and have a fresh fuel filter in the waiting. Though i'm still weary of the condition of my coil packs. Got it to run for quite a minute today, but it took quite a bit of work with the throttle.
regular old m60 swap
she idles! had a pretty serious fuel rail leak, bent the mounting tab to put more pressure on the fuel injector (temporary fix). the problem now is it doesn't rev over 2000ish (guess) rpm. i don't know if it's due to my older gas, or wiring, or mechanical. does the fact that i have an automatic harness change anything? currently i just have what i'm assuming is the transmission connector just dangling.Comment
auto harness is fine as long as you dont connect the harness to anything.
how old is your gas? i have 3month old 91oct sitting in my s13. When I got it running, it misfired, wouldnt rev etc. I emptied the tank mostly, threw some fresh 91 in and it ran perfect. I would reccomend flushing the old gas out if its over a couple months old.We're in deep now boys
1988 325i SETA - Daily driver
1988 340iL - Track car
My M60 V8 swap thread here
[oo==OO==oo]Comment
how old is your gas? i have 3month old 91oct sitting in my s13. When I got it running, it misfired, wouldnt rev etc. I emptied the tank mostly, threw some fresh 91 in and it ran perfect. I would reccomend flushing the old gas out if its over a couple months old.Comment
Quick idle clip from when I first got it going. My v band on my passenger side manifold doesn't mate perfectly and I need to weld a muffler on lol. It kind of revs up at first, from what I'm assuming is fluctuations from the old gas, there's no throttle input. http://cloud.tapatalk.com/s/598f5180...074023_170.mp4
Will upload properly later.
Sent from my SAMSUNG-SM-J327A using TapatalkLast edited by dothadance; 08-12-2017, 11:18 AM.Comment
Just drained my old gas. About 2.5 gallons of nice deep amber brown gas.
Sent from my SAMSUNG-SM-J327A using TapatalkComment
Installed fresh gas, runs the same and smokes like crazy! it doesn't smell like oil.. but idk. borrowed my brothers IR thermometer and my #5 cylinder is cold. Performed a stomp test and came up with code 1255 (#5 fuel injector). So i'm hoping my injector is just stuck open, hopefully running that old gas something just got stuck in there. With that being said, ever since i finished most of my exhaust i wondered if there was a left and right bank for the o2 connectors. (the 2 connectors are the same on the harness) Turns out, from what i've been reading, they are side specific and if you have them mixed up it will run like shit. so tomorrow i'm going to test fuel pressure, swap around fuel injectors and test codes, and swap my o2's around. wish me luck!Comment
what color is the smoke? whats smoking? also check that plug on the dead cylinderWe're in deep now boys
[oo==OO==oo]Comment
Driver side down pipe is covered in oil! I have a bunch it's from cylinder #5.
Cylinders 5 6 and 7. 180 psi. Cylinder 8, 90. Found the problem. I don't know wtf happened...[emoji17]
Ah shit........!
White smoke is generally oil.
Perhaps the rings are stuck from sitting?
How did you acquire the engine? Do you know any history?sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
did you figure out which side is which for the O2 sensors? both connectors on my harness were chopped off, I need to figure out which side is which before i solder connectors back onWe're in deep now boys
[oo==OO==oo]Comment
