regular old m60 swap
  • marshallnoise
    • Sep 2013
    • 3148
    #166
    Originally posted by dothadance
    Bought the boot new. For a 95 540 part # 13711747995. Would it matter if my throttle body came with traction control and the boot is for non asct engines? Not sure if my engine originally came with it but I cant think of any other reason...?
    Well the act engines had a second piece that bolted to the throttle body so I would imagine it would be a much different looking boot.
    Is that an OEM piece?
    Sent from my Z958 using Tapatalk
    Si vis pacem, para bellum.
    New Hawtness: 1995 540i/6 Claptrap
    Defunct too: Cirrusblau m30 Project
    Defunct (sold): Alta Vista
    79 Bronco SHTF Build
    • dothadance
      • Jun 2011
      • 1121
      #167
      Right, the traction control motors had a metal elbow. But both the ASC-T and non throttle bodies look identical (part #'s 13541747763 and 13541741671) sans metal elbow. It has to be the boot... Right?
      • marshallnoise
        • Sep 2013
        • 3148
        #168
        Right, the traction control motors had a metal elbow. But both the ASC-T and non throttle bodies look identical (part #'s 13541747763 13541741671)
        Yeah. Look through my thread and see what stock looks like. The elbow just can't be right.
        • dothadance
          • Jun 2011
          • 1121
          #169
          Yeah idk wtf happened. UGGGHHH I don't want to spend 100 ducking dollars on an intake boot.
          • JGood
            • Jan 2004
            • 7959
            #170
            hahahaha I can't stop laughing at that boot!
            Is it MTC brand? That's what I got and it fit fine. There's a very slight upward angle but nothing even close to that, lol.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • marshallnoise
              • Sep 2013
              • 3148
              #171
              I think the time is right to clock the engine mounts about 20 degrees. Hahaha!
              • dothadance
                • Jun 2011
                • 1121
                #172
                Yeah it's mtc. Who knew bmws came stock with a snorkel?
                • dothadance
                  • Jun 2011
                  • 1121
                  #173
                  New replacement boot on the way! Hopefully the first one was just some freak accident.
                  • marshallnoise
                    • Sep 2013
                    • 3148
                    #174
                    I gotta say, it's just plain weird that it would be so off.
                    • sgtskid
                      • 763
                      #175
                      Won't hydro lock again. ;)
                      Current: '91 DS M3, '03 TS M3 (6MT)
                      '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
                      Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
                      1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
                      IG: RDE_Fabrications
                      Check us out
                      Or YouTube --> HERE;
                      • dothadance
                        • Jun 2011
                        • 1121
                        #176
                        Lmao my thoughts exactly. New boot should be in today so hopefully I won't have to cut any holes.
                        • dothadance
                          • Jun 2011
                          • 1121
                          #177
                          Round 2 is at an acceptably bendable angle.
                          • dothadance
                            • Jun 2011
                            • 1121
                            #178
                            Did some stuff today. Driver side exhaust mani was contacting my engine mount preventing me from bolting it to the block. so I had to cut a chunk out of one arm. Got that figured out then headed to the back. The top heater core line was sticking a little further out so that when I connected the hose it contacted the back of the head. It might have been fine, but I cut it down a little and I trimmed the end of the hose some as well.
                            Played with some shifter stuff for a minute as well.
                            Picked this from an e36 318ti and it turn out ITS FITS PERFECTLY. It's the exact length that I need.
                            This is what my bay looks like now. I really need a new washer tank lmao
                            • kuan098760
                              • Mar 2016
                              • 7
                              #179
                              hey man im currently planning out a list of parts for my e30 m60 swap.
                              its an 87 325is automatic. Just wondering which drivesahft did you go with?
                              I read somewhere online;
                              The e30 m3 driveshaft works with no modification. The front half of an e28 535i can also be used with the back half of an e30.
                              Cliff notes: You use a stock, large guibo driveshaft (late 325e, e30 M3, or e36 328/M3 with 4 bolt rear).
                              As far as the mount goes. No modification is needed to the stock e30 manual transmission crossmember.
                              Note: 5 speed weights about 85lbs wet
                              For the clutch, you must use a 240mm flywheel only. However, any E36 or E39 B28 clutch kit will work.
                              [/COLOR]
                              whats a large guibo driveshaft? Im on a budget so i wont be able to buy a 800$ e30 m3 driveshaft naw mean? LOL by thew way isnt there a differnce between the auto and manual driveshafts?
                              • dothadance
                                • Jun 2011
                                • 1121
                                #180
                                [/COLOR]
                                Yeah that's all correct as far as I know. I got lucky and found a driveshaft from a 325e on craigslist for like $80. It needs to be a manual driveshaft as the automatic shafts are too short. The large guibo bolt holes are like 3.25 inches apart. My clutch setup is a single mass flywheel for an e39 (540 pretty sure) and clutch kit for an e36 328i. I chose a stage 1 clutch kit, but we will see how far that goes, seems like some have problems with it slipping and some don't.
