regular old m60 swap
  • dothadance
    • Jun 2011
    • 1121
    #301
    Originally posted by flyboyx
    i didn't realize you are in austin. i have been chilling at the airport holiday inn for the last 2 days. could have helped you work on it a little bit.
    Ha, that would've been nice. I've definitely been slacking lately, but my procrastination has reached its limit. I need to drive this bitch.
    • bobaflesh
      • Mar 2016
      • 69
      #302
      How is the project coming along? Any updates?
      • dothadance
        • Jun 2011
        • 1121
        #303
        she's fires up!... kind of. she dies as soon as i let go of the starter, and reving it doesn't help. time to stick my nose in some books.
        • delamaize
          • Nov 2013
          • 1460
          #304
          Check fuel pressure, and make sure you got all the vacuum lines capped.
          First start with mine:
          Capped these:
          Then this:
          Dumpster Fire Pilot
          • dothadance
            • Jun 2011
            • 1121
            #305
            Well my problem is she used to run, but after the rain messed up my ecu and my buying a new one, it still doesn't run. Thanks for reminding me to check my fuel pressure. I've been in a bit of a daze the past couple weeks. Gonna get that checked out this weekend. But I have a hunch that I bought a bad ecu.
            Edit: also, I have all my vacuum holes capped.
            • dothadance
              • Jun 2011
              • 1121
              #306
              Got a text from my brother with this picture
              Wtf man? There's a pos e34 8 spaces away from me that's been there for 5 years now, why me? Moved my car down the parking lot to a higher traffic area instead of out in the open. so hopefully they don't bug me again.
              • dothadance
                • Jun 2011
                • 1121
                #307
                Houston, we have liftoff.
                • jpod999
                  • Dec 2015
                  • 1401
                  #308
                  W00t! Congrats!
                  OBDI M62B44/6 swap
                  Transaction feedback
                  - jpod999
                  • dothadance
                    • Jun 2011
                    • 1121
                    #309
                    Worked on my car on Tuesday. Super frustrating partially satisfying. Went to address my coolant leak on my rear crossover. Found my vacuum cap on my brake booster nipple on the back cover had cracked. So that's good news and helps explain the running rough issue. But as I was taking the coolant pipe out one of the bolt hole tabs snapped off. Glad it didn't happen when I put it back on, and I'm glad I live down the street from a badass shop. My car is located at my dad's apartments and he's moving next weekend. So shits gotta move... Preferably on its own.
                    • dothadance
                      • Jun 2011
                      • 1121
                      #310
                      Same
                      But different
                      • dothadance
                        • Jun 2011
                        • 1121
                        #311
                        On to parking spot #3 lmao
                        Dad moved across town. So i rolled her down the block to a lesser used street...
                        • dothadance
                          • Jun 2011
                          • 1121
                          #312
                          With that being said I fixed my coolant leak!
                          • csm-e30
                            • Oct 2014
                            • 95
                            #313
                            Do you have power windows? Did you run into the problem of no blower and no windows once you swap?
                            • dothadance
                              • Jun 2011
                              • 1121
                              #314
                              exhaust is done back to the muffler location. runs rough, going to check my ignition system in the morning.
                              • dothadance
                                • Jun 2011
                                • 1121
                                #315
                                for some reason my passenger side window doesn't work anymore, but my driver side and my blower still work.
