a few days ago i was able to get some time on the car, took my multimeter to all my coils (all tested between .4 and .8 ohms), checked all my spark plugs (good even wear), checked fuel pressure (low fuel pressure). My fuel pump was a cheap replacement that i installed ~7 years ago, so i went ahead and installed a new one along with a new filter. Haven't tested pressure since, but i no longer have the intermittent dying issue, and my car seems to pull like never before. That being said my car still misses 4500 and up, and still has the 5kish rev limit. no cel.
regular old m60 swap
Originally posted by JGood View PostWhat chip is currently in it? With the stock chip, if the DME doesn't recieve a VSS, it will engage the top speed governor at 5200rpm.
I'm doubting that's the issue since you noted a 4500rpm miss, but just something to keep in mind.
I'd get the fuel pressure tester back on there.
I'll hopefully be able to knock out some more tests here soon.
Fuel pressure at idle is 42 psi and climbs up towards 50 at wot. In the video I hung at 3/4 throttle for a second before going wot, hence the way the rev limit changed a little bit. . http://cloud.tapatalk.com/s/5e77b975...322_141344.mp4 Sent from my BND-L34 using Tapatalk
A lot of tinkering these past couple weeks. Checked resistance of: IAT, CMP, TPS, coolant temp sensor, all within spec. Checked again, all eight coil packs have equal resistance. Cleaned the ICV, removed the wedge on the throttle plate, replaced a vacuum cap on the throttle body, and installed a new fuel pressure regulator vacuum hose. Tested the resistance on the crankshaft sensor, 396 ohms...... everything that i've been seeing says it's SUPPOSED to be 560ish. I've only ever seen that ckp's are either good or bad, but when a ckp is bad the car wont run... But the resistance is weird and that would kind of explain the weird stuff i've been experiencing, so a new one is on the way.
AAAANNNDD
I installed a 3.25 LSD that i swapped from my roommates e28!! This thing is so fresh, absolutely zero slop! Such a good deal.
