regular old m60 swap
  • dothadance
    • Jun 2011
    • 1121
    #91
    what's the difference between this picture and the one from a month ago you ask?
    She's all bolted in!!!!
    Here's a shot of my lip :(:( dang puddle
    You'd never know...
    • ncrmtrsprtsE30
      • May 2015
      • 204
      #92
      You still running ABS?
      Did you use any subframe spacers?
      The "Because Race Car" M60 V8 Build Thread
      On Instagram Straight Flexin' #BecauseRaceCar
      • dothadance
        • Jun 2011
        • 1121
        #93
        Still have abs. No subframe spacers as of yet, I have my motor as low down as possible, but if I start feeling vibrations/start shredding guibos I'll add some.
        • dothadance
          • Jun 2011
          • 1121
          #94
          My current predicament
          • marshallnoise
            • Sep 2013
            • 3148
            #95
            Nothing a 2" holesaw can't fix.
            Sent from my SAMSUNG-SGH-I337 using Tapatalk
            Si vis pacem, para bellum.
            New Hawtness: 1995 540i/6 Claptrap
            Defunct too: Cirrusblau m30 Project
            Defunct (sold): Alta Vista
            79 Bronco SHTF Build
            • modernist
              • Apr 2014
              • 283
              #96
              Can you mount the oil filter housing above the ABS pump?
              1986 327i
              transaction feedback
              DIY thing
              meh
              • dothadance
                • Jun 2011
                • 1121
                #97
                Lol, if only it were that easy! Shouldn't be that big of a deal though.
                • dougie30
                  • Apr 2012
                  • 1708
                  #98
                  what mounts are those?
                  M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                  • dothadance
                    • Jun 2011
                    • 1121
                    #99
                    Condor speed shop solid m20.
                    • dougie30
                      • Apr 2012
                      • 1708
                      #100
                      The fit with the m60?
                      Sent from my LGLS740 using Tapatalk
                      • dothadance
                        • Jun 2011
                        • 1121
                        #101
                        well i made the arms specifically for them lol. i spent $10 on the metal and i already had the m20 mounts vs. $225 for garagistics mounts + another $120 for revshifts solid mounts (not knocking their product i just dont have that kind of money haha). now obviously i wouldn't have to buy the solid revshift mounts, but i still saved quite a bit of money.
                        • dothadance
                          • Jun 2011
                          • 1121
                          #102
                          that's a good question, not really sure how much room there is over there. i plan to just use my left over metal from my motor mounts and make some sort of bracket to just "slide" the filter 3 or so inches towards the drivers side.
                          • dothadance
                            • Jun 2011
                            • 1121
                            #103
                            also, i'm looking for the larger of the two coolant pipes that run over the valley pan. part number 11531736830, if any of you have one i'd gladly take it off your hands. it seems the m62 pipe has a different part number, does anybody know if theres any actual difference?
                            • dothadance
                              • Jun 2011
                              • 1121
                              #104
                              anybody have incite as to clutch line setup? researching right now.
                              • dothadance
                                • Jun 2011
                                • 1121
                                #105
                                seems like the stock e30 slave line SHOULD work. gonna go ahead with that and make/find a hardline to fit from the hose to the master
