regular old m60 swap
  • ncrmtrsprtsE30
    • May 2015
    • 204
    #106
    change over to the 740il oil filter housing. thats what im running... oh but your keeping the ABS..... out with the ABS you dont need it anyway..
    The "Because Race Car" M60 V8 Build Thread
    On Instagram Straight Flexin' #BecauseRaceCar
    • dothadance
      • Jun 2011
      • 1121
      #107
      What's the difference between the two?
      • dothadance
        • Jun 2011
        • 1121
        #108
        Ah, the e38 ones don't mount to the cover. Yeah if I wasn't keeping abs that would be pretty perfect.
        • dothadance
          • Jun 2011
          • 1121
          #109
          Due to the shitty timing my harness is going to take 2 fucking weeks to get here! It should've taken 3-4 days. This is killing me. :(
          • dothadance
            • Jun 2011
            • 1121
            #110
            Harness is in the building!!!
            • delamaize
              • Nov 2013
              • 1460
              #111
              Which harness are you using? I have an automatic 540i harness, I'm looking for other options. Although I have though about building my own.
              Dumpster Fire Pilot
              • Miked6187
                • Aug 2015
                • 15
                #112
                Mounts are all welded!!!
                And I just paid for a harness! Shit is coming together
                Where did you get your measurements to make those mounts?
                Sent from my SM-N900T using Tapatalk
                • dothadance
                  • Jun 2011
                  • 1121
                  #113
                  I dropped the engine/trans in and bolted in the trans and d/s. Then jacked up the engine into place. Took a couple side to side measurements to make sure she was square. Not particularly hard, just time consuming... but time I have..
                  • dothadance
                    • Jun 2011
                    • 1121
                    #114
                    It's a 530ia. Wish it were manual but whatevs
                    • Miked6187
                      • Aug 2015
                      • 15
                      #115
                      Would you happen to still have those measurements? I don't have a Trans yet but I'm trying to get everything ready for the swap before I start so I can have my car back up and running asap. If u have them that would be great.
                      • dothadance
                        • Jun 2011
                        • 1121
                        #116
                        You using m20 mounts?
                        • Miked6187
                          • Aug 2015
                          • 15
                          #117
                          Yes
                          • Miked6187
                            • Aug 2015
                            • 15
                            #118
                            So do u still have those measurements?
                            • dothadance
                              • Jun 2011
                              • 1121
                              #119
                              Took my dad's car for a leisurely drive down to San Antonio on Monday.
                              Both vc's the coolant tube, icv, x20, and an alternator! So glad that 3 hour round trip was worth it.
                              • dothadance
                                • Jun 2011
                                • 1121
                                #120
                                Also saw this toasted bay right through the valve cover.
