E30. M60. California Smog Legal / BAR'd.
  • robiniscool
    • Jul 2010
    • 299
    post pictures of your "modified" exhaust i need ideas!
    • 36brua
      • 689
      unfortunately my pics of exhaust build were crap.
      basically I didn't attempt top use the modified single outlet manifolds (X5? see garagistic site for ref.) . so Ive no idea if they would pass BAR.
      I wanted a 'stk' configuration 4>2 /2>1
      at heads : cut off flange end of stk header leaving as much 2bl wall header as possible to fab onto. used SS pipe
      reused stk 2 bolt flanges at ends, 'headers' end next to blk/trans joint. Stacked, not side by side. pointing down at 45*+- . this is tight but workable.
      Reused the stk 2>1 connector/pipe w/ reshaped pipe to end of headers.
      Then 21/2" back to Calif legal 540 walker cats w/ O2 sensors. dual 21/2" cat back to muffler.
      The BAR ref commented the headers had been modified but were representative/ close enough to what his diagrams showed.
      Your results may vary.
      I probably paid more for the exhaust system then all the rest of the swap.
      My CA legal M60 swap
      The happening in our garage
      • jpod999
        • Dec 2015
        • 1401
        Originally posted by 36brua
        Cooling:
        Mishimoto M Z3 radiator
        Spal pusher fan
        Rear waterpipe between cyl heads from M6211531702201 no welding required
        Did you just drill and tap a hole for the coolant sensors in the M62 pipe?
        OBDI M62B44/6 swap
        Transaction feedback
        - jpod999
        • 36brua
          • 689
          No, the one we had already have the holes in it, they were just plugged.
          http://www.realoem.com/bmw/enUS/show...36#11531702201
          remove 8 and 9
          And the diagram on RealOEM is the older style
          • jpod999
            • Dec 2015
            • 1401
            remove 8 and 9
            Nice! I kinda figured that was possible but haven't had the waterpipe in front of me to check. You just made my swap easier, thanks!
            OBDI M62B44/6 swap
            - jpod999
            • 36brua
              • 689
              Isn't that what these forums are all about making stuff easier... OO no never mind this is r3v... hahaha
              • jpod999
                • Dec 2015
                • 1401
                hahahaha yup!
                OBDI M62B44/6 swap
                - jpod999
                • P Arkus
                  • Dec 2012
                  • 325
                  Hahaha and sig'd
                  Patryk:up:
                  Instagram: @parkus08
                  91 BMW 325is ///M-Tech II
                  08 VW .:R32
                  04 Audi A4 Avant 1.8TQ
                  • 2mAn
                    Señior Mod
                    • 20173
                    Any pics of what you had to do with the headers? Ive thought this would be something that was possible. Congrats on doing it the right way
                    Simon
                    Current Cars:
                    -1966 Lotus Elan
                    -1986 German Car
                    -2006 Volkswagen Jetta TDI
                    Make R3V Great Again -2020
                    • 36brua
                      • 689
                      still no pictures, I am guessing you read the post above I wrote out a while back about how I went about the headers.
                      I'll be swapping the motor for an "upgraded" m60 in the next month or two... hopefully can take some pictures when the motor is out.
                      • WYZEUP
                        • Jun 2015
                        • 105
                        Have you got any pics of how you ran your coolant pipes using that rear accumulator pipe as i may go that way to make my swap easier and give me more clearance
                        • ckarsonkidd
                          • Jul 2011
                          • 446
                          This is great to see and all the details for it kept asking myself for longest if this could be legal
                          • wspellmann
                            • Sep 2016
                            • 110
                            Any news on the exhaust photos?
                            My current E30 M62B44 swap
                            • ogslick
                              • Apr 2017
                              • 21
                              headers
                              So just to confirm. The only thing you left stock on your exhaust was the flanges?
                              The referee was ok with using all new exhaust piping?
                              Did you need to follow any guidelines like runner length and size, collector and cat location etc..?
                              Does it look close to the stock header design?
                              What can make the headers fail inspection?
                              Thanks for the info I'm in San Jose doing a s62 swap, trying to figure if i should custom fabricate or cut/bend/rotate my stock headers.
                              • nick526
                                • Jan 2011
                                • 258
                                I'm working on the S62 swap as well. Pretty far away from getting it BAR'd at the moment but would definitely love to know what if any leeway the ref will give with the exhaust manifolds.
                                I miss the old BMW
