NVH increase with LSx swap?
  • kristov
    • 222
    How much would you say the NVH from the engine/transmission increased with your LSx swap?
  • george graves
    • 19996
    What the heck is NVH?
    Originally posted by Matt-B
    • JGood
      • Jan 2004
      • 7959
      Noise, Vibration, Harshness. Is your car a Serta Mattress, or a washing machine with a cinder block in it?
      OP, I'd assume since LSx's came in a wide range of nice comfy OEM vehicles, that it could be as pleasant as you want it to be, just chose the appropriate mounts.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • george graves
        • 19996
        Oh, I thought it was some emission thing.
        • kristov
          • 222
          Yes, input regarding mounts used would be greatly appreciated!
          • garretvs
            • 464
            We used rubber mounts: E34-540 engine mounts, and a standard GM rubber mount for the transmission. No problems, smooth idle, etc. Use of polyurethane mounts would make it an uncomfortable daily driver, which we would advise against.
            E30-LS1 aka. 357is
            email us to pick up our LS1 swap guide
            E30-LS1 KITS now available!!
            E30LS1@gmail.com
            e30ls1.com
            • kristov
              • 222
              Did you consider the oem Corvette mounts?
              • shiboujin
                • Feb 2006
                • 2791
                I have the sikky kit. The vibrations are minimal and actually better than my S52 turbo was. The noise is definitely there. I think the engine is just loud. It's not that the sound travels through the mounts. The motor is just louder than other factory motors. I also have my hood spaced up and not much for sound deadening to my firewall. But why wouldn't you want that? lol.
                I was actually surprised at how nice the NHV was with this motor.
                • Gertech
                  • Jul 2013
                  • 180
                  Kristov, I replied to your PM about this. As others have stated, using OE mounts would be the best way to keep things smooth and quiet. I'm using factory GTO motor mounts and transmission mount.
                  • kristov
                    • 222
                    Any pictures of the GTO motor mounts?
                    • kristov
                      • 222
                      Do you still think the Corvette mounts are better (as stated in the manual)?
                      And would they be a direct swap without the need for altering someting (because of height)?
                      • marshallnoise
                        • Sep 2013
                        • 3148
                        On my e34 with the m60, I have the Revshift 95A poly mounts. While I haven't daily driven it yet, I highly doubt it will be unbearable when I do drive it full time next month. Really, they are V8s and they are supposed to give the car a little rumble. I would imagine NVH with an LS1 would be about the same if you used stock mounts. If you used poly, it would be a bit harsher, but it is really nothing to worry about.
                        Si vis pacem, para bellum.
                        New Hawtness: 1995 540i/6 Claptrap
                        Defunct too: Cirrusblau m30 Project
                        Defunct (sold): Alta Vista
                        79 Bronco SHTF Build
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          Update: After three days of commuting in the car with the Revshift 95A mounts, the NVH is barely noticible and I would say unobtrusive. The only place you feel it is at idle. The car rocks a bit when you gas it at a light, but that's it.
                          • DER E30
                            • Sep 2013
                            • 2347
                            Little late, but my truck with LS swap and poly engine and trans mounts (pfadt racing) is smooth and easy to drive. Most of my NVH is noise from the wind!
                            -Christian
                            • HennaE30
                              • Apr 2014
                              • 1965
                              Another thing to keep in mind is what cam you decide to go with. If it's a taller cam, expect a little bit more vibration due to the lope. If your looking for a little smoother ride, keep the stock cam, they idle very nice. (I have an LS1 Camaro with a stock cam)
                              Originally posted by flyboyx
                              how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                              Originally posted by Northern
                              beer is my new liver cleanse.
                              Henna - '84 Hennarot 325e
                              Lola - '89 Schwarz 325is - being saved
                              Christine - '88 Schwarz 325is - Spec E30 Racecar
                              '01 White F150 Lariat 4x4 Supercrew - Daily
                              Dad's '05 Interlagosblau M3
