Originally posted by jpod999
View Post
Project Overly Ambitious
Originally posted by jon2681 View PostIt helps if u weld the nuts to pedal box after u drill the holes thru the firewall, had to do pedal box install by myself so it helped tremendously
Sent from my Nexus 6P using Tapatalk
Originally posted by jpod999 View PostAll this weekend and most of next week I will be on the East Coast meeting my newest nephew. Beforehand, I wanted to make sure that I got the rear subframe cleaned, strengthened, and painted.
The welds don't look super pretty but I got plenty of penetration, so they should hold up nicely. Chose blue because why the hell not?
I got the strengthening plates from Garagistic: http://store.garagistic.com/e30-rear...l-reinforcment
When we return I have to reseal the new rear diff and then reassemble the rear end to go back in the car.
Originally posted by jpod999 View PostSaturday afternoon was a HOT day, so naturally that's when my dad, roommate Kevin, and I decided to shoehorn the engine and transmission into my car. It took us about an hour and a half from start to finish to get them bolted into the chassis. I tried at first to do it with the tranny crossmember bolted on, but quickly pulled it off to gain clearance.
I beat in the firewall a little bit, but didn't go overly crazy, with the motor in place there is a good inch or inch and a half clearance to the coolant crossover pipe using the mounting holes closest to the firewall (Garagistic mounts).
My drivers side engine mount isn't lining up as you can see in the photo above. I think I remember in reading 36brua's thread that he had this same issue and modified the mount. Has anyone else run into this issue?M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
Originally posted by WYZEUP View Postwith that gearing its very long. 40mph is about 1500rpm in 4th
Heck, I've heard an E39 M5 is very nice on the highway with a 2.65 rear.
Originally posted by dougie30 View Postany more info on the motor mounts mine do the exact same thing??
Originally posted by dougie30 View Postany more info on the motor mounts mine do the exact same thing??Dumpster Fire Pilot
Originally posted by dougie30 View PostProbably shaving the rubber down a bit so it sits more flat
Hi before shaving any thing make sure the engine is parrallel to the subframe.
Since the one side is sitting flat. Put a level across the valve covers and compare to when its on the subframe. Front rails could be tweaked
You've probably checked if rotating the mount makes any difference. If your mounts have offset studs lift weight off mounts and rotate also turn end for end.
Even after modifying the metal mounts you need to clock the poly mounts . Be sure to mark their orintation
Or f it and make shims but chk eng / frame relationship first. You need to watch your pan to rack clearance if you start shaving
