Project Overly Ambitious
We're in deep now boys
1988 325i SETA - Daily driver
1988 340iL - Track car
My M60 V8 swap thread here
[oo==OO==oo] -
Brake update!!
I was able to get my brakes installed and fully bled. It only took three installs and removal of the pedals before I was able to get it done haha. Now I need to get the remote adjuster cable installed and get the dash back in.Comment
only 3 installs??? im over that number and i haven't even finished plumbing...We're in deep now boys
[oo==OO==oo]Comment
I had to have done it at least 5 times and I need to take them out again for bench bleeding and balance adjuster install.
Lol, this is not something you get right on the first try, for sure.
Sent from my Nexus 6P using TapatalkComment
am i being too optimistic thinking I can bleed everything without bench bleeding? I have an idea about bench bleeding keeping it installed. I set my balance bar to about half, and I've installed the remote adjuster already. The knob will be mounted where the OBC was.We're in deep now boys
[oo==OO==oo]Comment
The last time I pulled the pedals out was to adjust the stroke of the pedals. Basically, I adjusted them as far up as they can go. I probably could have gone in a little bit, but I wanted to make sure I could fully depress master while bleeding.
I bench bled in the car, super easy if you don't have ABS. Bolt in your pedals, connect up your lines that go into the engine bay and your reservoirs. 1. With a helper, slowly depress your brake pedal, 2. plug the engine bay side of the lines with your finger as the pedal moves back up to neutral, 3. remove finger from engine bay side of line and slowly depress pedal- do all this until you have clear fluid coming from the lines in the engine bay. Connect up your braking system to the rest of the system and bleed your brakes. Bleed both passenger side corners at the same time- if you have speed bleeders it's quite easy to do both at once and even by yourself. If you don't have speed bleeders, you will need two helpers to accomplish this part.
dasmanschaft01- do you have a prop valve plumbed into the rear?
I just worked on the remote adjuster this morning, I'm going to run it next to the ebrake handle.Comment
I assume thats proportioning valve.
Unless theres an OE one somewhere, no. Just using the remote cable adjuster.
Thats basically how I was gonna do bench bleeding, except rather than a finger, put a hose from the output into some clean fluid.We're in deep now boys
[oo==OO==oo]Comment
that's the stock one- it is in the drivers side of the engine bay bolted into the rear line.
That method of bench bleeding should work.Comment
Ah that's what that is. Just when you think you know where everything is on these cars, you learn something new. Ill leave the stock one in, unless it causes an issue the balance bar can't fix.We're in deep now boys
[oo==OO==oo]Comment
My dash is most of the way back in- I got the dash itself bolted in last night with the help of my friend Kevin, then spent time today getting the glovebox back in place as well as the M42 DME mount and HVAC panel. It was somewhat of a puzzle putting it all back together since I had taken it out back in October and had forgotten everything. Luckily I tagged and bagged much of it.Comment
The m42 mount ecu mount didn't work for us the harness was not long enough. You may have better luckMy dash is most of the way back in- I got the dash itself bolted in last night with the help of my friend Kevin, then spent time today getting the glovebox back in place as well as the M42 DME mount and HVAC panel. It was somewhat of a puzzle putting it all back together since I had taken it out back in October and had forgotten everything. Luckily I tagged and bagged much of it.Comment
Does anyone have any insight into wiring up the old style Garagistic RPM module? Now that they have the plug and play one they don't have the instructions for the old style. I emailed them and never received a response- that legendary Garagistic customer service again...Comment
Give them a call. More responsive over phone.Does anyone have any insight into wiring up the old style Garagistic RPM module? Now that they have the plug and play one they don't have the instructions for the old style. I emailed them and never received a response- that legendary Garagistic customer service again...We're in deep now boys
[oo==OO==oo]Comment
