Project Overly Ambitious
  • wspellmann
    • Sep 2016
    • 110
    #166
    Originally posted by dasmanschaft012
    Give them a call. More responsive over phone.
    Yeah, I'm usually able to get answers over the phone too
    Sent from my Nexus 6P using Tapatalk
    My current E30 M62B44 swap
    • jpod999
      • Dec 2015
      • 1401
      #167
      As I get closer to “finishing” I’m getting more anxious to drive the damn thing. It starts up super well, just as if it came with the V8 from the factory- it’s a real morale booster.
      OBDI M62B44/6 swap
      Transaction feedback
      - jpod999
      • htseng
        • Sep 2009
        • 158
        #168
        Looking forward to seeing in the roads
        • jpod999
          • Dec 2015
          • 1401
          #169
          Cluster is in but has issues- when the car is started up the tach doesn't move. I wired in the original Garagistic tach splitter, I wonder if it's dead?
          OBDI M62B44/6 swap
          - jpod999
          • 36brua
            • 689
            #170
            Our does the same thing sometimes, did you try revving it?
            My CA legal M60 swap
            The happening in our garage
            • jpod999
              • Dec 2015
              • 1401
              #171
              That’s interesting, I probably should have just gone with the Dakota Digital box instead.
              OBDI M62B44/6 swap
              - jpod999
              • dasmanschaft012
                • Apr 2014
                • 642
                #172
                Does the Daktota box require a 4cyl coding plug like the garagistic module does?
                Im leaning towards designing my own, should be a simple cheap little board with the 4cyl coding plug.
                We're in deep now boys
                1988 325i SETA - Daily driver
                1988 340iL - Track car
                My M60 V8 swap thread here
                [oo==OO==oo]
                • jpod999
                  • Dec 2015
                  • 1401
                  #173
                  I think you tell it the signal coming in and the signal you want going out.
                  OBDI M62B44/6 swap
                  - jpod999
                  • Zacm829
                    • Jan 2008
                    • 1919
                    #174
                    Yep. That's what I'm using, simple to wire in and can support a variety of engine sizes in case you upgrade to a v10 later on...
                    1987 325i-M60b44 swap
                    • ReSoP
                      • Dec 2008
                      • 148
                      #175
                      So for anyone out there who is doing an M62 swap with the 6spd, this is proof that you don't need to run the E34 damper wheel and crank sensor. Just make sure to run the OBDII flywheel and transmission!
                      To make this happen I pulled the crank sensor out of the passenger side harness pack and pulled the wire out through the back of the harness pack so that I could run it down towards the transmission. This is shielded wire that runs to a three pin connector (one of the pins being ground). The biggest PITA with this setup is that the OBDII crank sensor has two pins and I found depinning the OBDI connector to be difficult. Once I had the connector depinned I cut off the pins and crimped on two new OBDII pins (the OBDI pins I guess are different and wouldn't go into the two pin connector- your mileage may vary) that I picked up at my local dealer. I extended the ground wire and crimped on a ring connector, shoved the two new pins into a two pin connector I had laying around which I then plugged into the crank sensor, and grounded the ring connector to the transmission via the crank sensor bolt.
                      Is it safe to assume that both engines use the same reluctor pattern? Just one being from the flywheel and other being damper? Could it really be as simple as rewiring one sensor? I have alot of questions going through my head right now.
                      • jpod999
                        • Dec 2015
                        • 1401
                        #176
                        Yup! (to everything above)
                        OBDI M62B44/6 swap
                        - jpod999
                        • jpod999
                          • Dec 2015
                          • 1401
                          #177
                          Behr Z3 S54 radiator and E34 540i throttle cable on order.
                          OBDI M62B44/6 swap
                          - jpod999
                          • dasmanschaft012
                            • Apr 2014
                            • 642
                            #178
                            I did the s54 rad as well. haven't test fitted yet. garagistic recommended a e34 530i throttle cable, it seems to work good
                            [oo==OO==oo]
                            • wspellmann
                              • Sep 2016
                              • 110
                              #179
                              The z3m rad fits perfectly.
                              • jpod999
                                • Dec 2015
                                • 1401
                                #180
                                Probably the same part number if I had to guess.
                                Good news!
                                OBDI M62B44/6 swap
                                - jpod999
