Project Overly Ambitious
  • jpod999
    • Dec 2015
    • 1401
    #46
    Originally posted by diegom6
    Looking to see updates in this build. Torque from a V8 it's pure pleasure!!
    After a week of vacationing in Peru I'm ready to get back to work. It was nice to meet you Diego!
    OBDI M62B44/6 swap
    Transaction feedback
    - jpod999
    • george graves
      • 19996
      #47
      sub'ed
      Originally posted by Matt-B
      • diegom6
        • 4447
        #48
        Same here JP! Glad you made safe back to home ;)
        Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
        • jpod999
          • Dec 2015
          • 1401
          #49
          This weekend I got started on the suspension rebuild. Saturday I pulled the struts and control arms, this job took me much longer than expected. When I was in high school I used to be able to go from car on the ground to both struts off in 30 minutes, it took me about an hour and a half to get everything off this time!
          Sunday I dropped the whole rear subframe, this took me about two and a half hours. Throughout this week I am going to disassemble the rear subframe. I am going to take the trailing arms and the front struts to a shop owned by some longtime family friends, they are going to replace all four wheel bearings for me. My small case S4.10 will be sold and a resealed S2.93 will go back in its place. Also for the rear subframe I have Garagistic strengthening plates as well as all new bushings from them.
          Here are some pics to keep things interesting:
          OBDI M62B44/6 swap
          - jpod999
          • theTBLACK
            • Jan 2013
            • 156
            #50
            This is awesome. Definitely subscribing. V8 swap is the best swap.
            Founder
            TheDirtyThirty
            instagram.com/thedirtythirty
            • jpod999
              • Dec 2015
              • 1401
              #51
              Thanks! It's been fun so far but I'm starting to get overwhelmed with how much left there is still to do. The worst part is that I keep thinking of things I can do
              OBDI M62B44/6 swap
              - jpod999
              • jpod999
                • Dec 2015
                • 1401
                #52
                I've been spending my lunch breaks breaking apart the rear end. I had a terrible time getting one of my half-shafts out of the hub! In the end it took a shit load of PB Blaster/Liquid Wrench, heat, and lots of hammering but it came out. I had to hammer it so much that the end with the threads is totally mushroomed now, it's a good thing I was already planning on replacing them! One has both boots torn and the other is starting to crack.
                I ordered new wheel rear bearings from Blunt that are supposed to come in today. I will bring them with me to work tomorrow and will drop them off with the trailing arms at the shop of a longtime family friend. I don't want to deal with changing the bearings so I'm just going to have them do it.
                This weekend I am hoping to have the time to burn out the subframe bushings so that I can thoroughly clean it and then weld in the Garagistic reinforcement plates.
                OBDI M62B44/6 swap
                - jpod999
                • DaWildBeast
                  • Mar 2016
                  • 244
                  #53
                  Thats mad work man keep at it looking for that final project!
                  • jpod999
                    • Dec 2015
                    • 1401
                    #54
                    Got the subframe bushings out of the subframe with the help of my dad while my wife cleaned the shit out of my old diff this weekend. It took a lot longer than I thought it was going to. We ended up using a drill to remove as much of the rubber as I could, then hammered out the center sleeve. Then we used a hacksaw to cut a slit in the outer sleeve which then made it easy to hammer out of the subframe. Not that exciting of a picture, but text only updates are boring!
                    This week I'll be doing the rear wheel bearings with the help of our shop owning family friends. I also ordered new rotors for all four corners, now I have to figure out how to rebuild the calipers.
                    OBDI M62B44/6 swap
                    - jpod999
                    • jpod999
                      • Dec 2015
                      • 1401
                      #55
                      Rear wheel bearing replacement done!
                      OBDI M62B44/6 swap
                      - jpod999
                      • DaWildBeast
                        • Mar 2016
                        • 244
                        #56
                        Got the subframe bushings out of the subframe with the help of my dad this weekend. It took a lot longer than I thought it was going to. We ended up using a drill to remove as much of the rubber as I could, then hammered out the center sleeve. Then we used a hacksaw to cut a slit in the outer sleeve which then made it easy to hammer out of the subframe. Not that exciting of a picture, but text only updates are boring!
                        How long did it take you to do this?
                        • jpod999
                          • Dec 2015
                          • 1401
                          #57
                          To get both subframe bushings out manually it took probably 1.5 hours. I started to burn them out but my dad got nervous that the cops would come and give us a pollution ticket.
                          OBDI M62B44/6 swap
                          - jpod999
                          • Sharon97
                            • May 2016
                            • 3
                            #58
                            This is Haye’s second fight of his Haye vs Gjergjaj Live fight comeback in his Haye vs Gjergjaj live battle against the 31-year-old Gjergjaj. Earlier this year, Haye steamrolled over fringe contender Mark de Mori in stopping him in the first Haye vs Gjergjaj Live Streaming spherical last January. It wasn’t a fight at all because de Mori gave the look of somebody who had no suggest the way to fight. It was all Haye in getting a Haye vs Gjergjaj fight Live fast stoppage win. That fight was an embarrassment to observe as a result of it absolutely was such a terrible Haye vs Gjergjaj Live Stream mate. It wasn’t that Haye looked great. It was more of a case of de Mori merely being terribly, very unhealthy that created Haye look thus smart in comparison.
                            • flyboyx
                              • 8371
                              #59
                              well, you do live in cali.
                              Gigitty Gigitty!!!!
                              • jpod999
                                • Dec 2015
                                • 1401
                                #60
                                Yeah I wasn't kidding about getting the ticket. That's why I put the fire out and grabbed my drill. The Bay Area is a strange place!
                                OBDI M62B44/6 swap
                                - jpod999
