boosterless brake bias valve
  • dougie30
    • Apr 2012
    • 1708
    I have the garagistic booster less brake setup with the willwood master cylinders. Im curious on how other have ran a brake bias valve with the duel master cylinder setup??
    I feel having the bias valve in line with just the rear brakes wouldn't help, should it not be controlling both front and rear? on a normal master cyl setup its just one line in one line out?
    not sure how to rout one but any info (preferably pics ) would be awesome.
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • e30_302
    • Sep 2013
    • 453
    If you're using dual masters I'd use a balance bar vs a prop valve.
    • dougie30
      • Apr 2012
      • 1708
      I believe this setup has a balance bar, just nearly impossible to get to once installed.
      • FredK
        • 14763
        It already comes with a balance bar, so if you're concerned about access, get a remote balance bar adjuster and mount it in a more convenient area.
        As a part of installing the setup into your car, it's likely you will have to adjust the master cylinder input rods after you plumb the system in, and dial in the balance bar adjustment.
        • dougie30
          • Apr 2012
          • 1708
          Remote balance bar adjuster?? Never new that existed. Is it like linkage or something??
          Sent from my MotoG3 using Tapatalk
          • e30_302
            • Sep 2013
            • 453
            http://www.speedwaymotors.com/Wilwoo...able,1388.html
            • dougie30
              • Apr 2012
              • 1708
              Awesome, thank you
              • jpod999
                • Dec 2015
                • 1401
                With the remote adjuster you will need to modify the garagistic bracket slightly: http://www.r3vlimited.com/board/showthread.php?t=394077
                OBDI M62B44/6 swap
                Transaction feedback
                - jpod999
                • 36brua
                  • 689
                  I installed both Wilwood proportioning valve and cable adjuster.
                  Clearanced the garagistic bracket as shown in other post. Set balance bar 'neutral'.
                  My brake set up is E36 frnt , E 30M3 rear. I replaced the factory proportioning valve to rear brakes with the Wilwood adj. Installed the proportioning valve to dial in the f/r bias and use the cable to tune. I'm planning to install larger 330 frnt brakes so resetting bias is easier
                  GL
                  My CA legal M60 swap
                  The happening in our garage
                  • Madhatter
                    • Oct 2004
                    • 966
                    inline valves are basically just pressure regulators. So you use the balance bar on the pedal box to set your bias, front to rear, then fine tune with a proportioning valve. Wilwood make a M10x1.0 one to fit bmw brake lines that will go right in.
                    Just a little project im working on
                    - http://www.lse30.com -
                    • 36brua
                      • 689
                      True - oops yes I do have balance bar set a bit to front after road test
                      • dougie30
                        • Apr 2012
                        • 1708
                        This is all great info I appreciate it, so balance bar adjust and manual prop valve? Do any of you have pictures of your brake line set up? I'm very interested.
                        • Madhatter
                          • Oct 2004
                          • 966
                          I put my proportioning valve in the engine bay because the car is still street driven, so you can't have it adjustable from within the car when running. Im going to relocate it inside now im putting the cage and stuff into the car. Probably going to mount it on the trans tunnel so it's in easy reach.
                          • dougie30
                            • Apr 2012
                            • 1708
                            Why does it have to be in the bay if it is street driven? I was hoping to put mine on the trans tunnel too
                            • delamaize
                              • Nov 2013
                              • 1465
                              I'd say it's probably a law in Australia.
                              I want to put a proportioning valve on mine also, but I'm still running ABS, and I am not sure if I should put it before or after the pump.....
                              Dumpster Fire Pilot
