From Dad's DD to my new toy... M62B44 swap time!!!
  • dasmanschaft012
    • Apr 2014
    • 642
    #76
    I had a similar problem with the rear water plate bolts. Snapped 4 clean off in the block.
    I ended up drilling through 3/4 of them, tapping a size up with no helicoil. The 4th one I tried using an easy-out, which snapped off in the bolt. I dont have anything that drills thru hardened tool steel. I ended up welding a nut on it, and it actually unscrewed the bolt after a few nut attempts. I put a thin layer of silicone on both sides of the gasket, I never want this to leak ever again.
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
    • wspellmann
      • Sep 2016
      • 110
      #77
      Fuck me running. I'm trying to get back into this project and it's gonna be a bitch just trying to remember what's next.
      My current E30 M62B44 swap
      • jpod999
        • Dec 2015
        • 1401
        #78
        That's a real struggle!
        OBDI M62B44/6 swap
        Transaction feedback
        - jpod999
        • wspellmann
          • Sep 2016
          • 110
          #79
          So I've been "catching up" by doing some stuff and things...
          • wspellmann
            • Sep 2016
            • 110
            #80
            Z3 2.9 turn lock-to-lock with spacers installed. I was not into the idea of bending the tabs too much so this took much longer than it should have.
            • wspellmann
              • Sep 2016
              • 110
              #81
              Gave the trans a little TLC with a brass wire brush.
              • wspellmann
                • Sep 2016
                • 110
                #82
                Installed front and rear ST Suspension sway bars, Megan Racing Coilover kit, 5-lug swap/BBK kit
                5-lug and BBK components
                Front:
                • E36 Front hubs/bearings
                • Elcoy's 5-lug swap sleeve for spindle/bearing
                • Elcoy's BBK adapter
                • E46 M3 Calipers
                • E46 M3 Rotors
                Rear:
                • E36 Z3 Hubs
                • Elcoy's BBK adapter shaved down 2mm for Z3 hubs vs. M3 $250+ hubs
                • E30/36 Bearings (same part #)
                • E39 540i rear calipers
                • E46 325i rear rotors
                • wspellmann
                  • Sep 2016
                  • 110
                  #83
                  These style 5's are too big at 17x8, especially with the offset of ET20, the nuts on the inside rim were scraping on the calipers.
                  The off-center control arm bushings were too much caster with the bigger wheels/tires also.
                  Click image for larger version  Name:	20190811_174844.jpg Views:	0 Size:	68.4 KB ID:	9864535
                  • wspellmann
                    • Sep 2016
                    • 110
                    #84
                    So back to centered bushings it is...
                    • wspellmann
                      • Sep 2016
                      • 110
                      #85
                      The bad fitment of the Style 5's I bought on a whim got me to start using my google-fu for what I wanted in the first place...
                      STYLE 32!!! A set of 4 17x7.5 ET41 sourced from 3 different sellers on Ebay
                      Click image for larger version  Name:	20190819_151204.jpg Views:	0 Size:	66.1 KB ID:	9864539
                      • wspellmann
                        • Sep 2016
                        • 110
                        #86
                        Those 32's look so damn good on the E30. The rotors filling almost the entire inside is sexy AF too
                        • wspellmann
                          • Sep 2016
                          • 110
                          #87
                          Got a set of 225/45/r17 Pilot AS/3's with 80% tread for a really good deal. One is already mounted. Waiting for the 4th wheel to arrive to get the other 3 mounted.
                          • wspellmann
                            • Sep 2016
                            • 110
                            #88
                            Style 5 vs 32... discuss
                            • wspellmann
                              • Sep 2016
                              • 110
                              #89
                              Moved to a more convenient spot in the garage.
                              • wspellmann
                                • Sep 2016
                                • 110
                                #90
                                aaand I finally did a test fit last night of just the motor and mounts!!! Seeing the M62 between the frame rails really reinvigorated me. I'm determined to get this done now!
                                I got it all tucked in by my damn self too. I got the bushings and bolts all lined up on my first 15th try.
                                Click image for larger version  Name:	20190825_212736.jpg Views:	0 Size:	74.2 KB ID:	9864553
                                Click image for larger version  Name:	20190825_212726.jpg Views:	0 Size:	76.1 KB ID:	9864554
                                Click image for larger version  Name:	20190825_212746.jpg Views:	0 Size:	75.6 KB ID:	9864555
