92 Mtech vert LS daily driver swap
  • jon volk
    • Dec 2004
    • 524
    #46
    Its actually a Powerdyne part. Mispoke on my first post.
    Formerly 666 Fabrication
    https://www.youtube.com/@CouchBuilt
    • jpod999
      • Dec 2015
      • 1401
      #47
      Edited my post. I just posted your quote so that he could see the sizes etc.
      OBDI M62B44/6 swap
      Transaction feedback
      - jpod999
      • jon volk
        • Dec 2004
        • 524
        #48
        Has some initial issues to deal with. The original 2.79 open diff I installed ate the pinion bearing within 4 miles. I can only assume it was dropped at some point for how fast the cage disintegrated. I bought a 2.79 LSD and that has been good. The trans fluid also developed a pepto bismal hue indicated the converter or trans had water in it. I tore the trans down and rebuilt it and did the required mods to make it a full manual deal. Good thing I tore it down as the frictions had started to delaminate from the backing plates.
        Drove it to work this morning and coolant temps never got over 183. Cruised at 3k rpm 75 and made the 60 mile trek without issue. Ill probably go to a hydroboost setup in the near future. Not a huge fan of the manual brakes so far.
        Machined center support for better fluid flow on the direct feed mod.
        Shit that washed off all the hard parts as they were cleaned.
        Machining the pressure plates to get .050" of clutch clearances. I didn’t want to wait to order thinner steels, so this was the easiest way.
        Reunited with the rest of the Alpinewies
        • jpod999
          • Dec 2015
          • 1401
          #49
          It is insane how quickly you built this thing, skills!
          OBDI M62B44/6 swap
          - jpod999
          • mr2peak
            • 2388
            #50
            That was a quick build! Damn
            Drive it hard. Maintain it well.
            A Topless Memorandum
            • flyboyx
              • 8371
              #51
              you mentioned hydroboost. are you planning to go with the sikky kit? if you want to save some money, i think they will sell you the machined parts from both ends of the booster for about 3-400 bucks and you can source the rest of the parts yourself. i looked into this about a year ago, but it turns out they won't work with an s62.
              Gigitty Gigitty!!!!
              • jon volk
                • Dec 2004
                • 524
                #52
                Thanks for the tip. $1200 for the complete setup is a tough nut to swallow when the rest of the stuff can be sourced so cheaply.
                • Pootis
                  • 636
                  #53
                  I did the sikky style hydroboost on my own with a chevy astro booster it's not that difficult and way cheaper to do it that way
                  1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                  COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                    • 37833
                    #54
                    Great work Jon! Always love seeing your builds.
                    Grover Beach, California
                    BimmerHeads.com
                    • jon volk
                      • Dec 2004
                      • 524
                      #55
                      Been daily driving the car all month. Finally had a chance to weigh the car. Comes in at 3160lbs. Prior to the swap it was 3020. Late model verts arent exactly light.
                      Ordered a Vbox sport so Ill be able to get some data on the car. I also need to finish buying the last of the nitrous parts I need.
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #56
                        Damn dude, nice work! Always nice to see another heavily modded MTII 'vert out there :)
                        • jon volk
                          • Dec 2004
                          • 524
                          #57
                          Sold the nitrous after going through a bottle in like half an hour. Too much hassle with refills.
                          Picked up an Eaton M122 off a GT500. It already has a 2.4" pulley on it, so combined with the 7.5" crank pulley, it'll be turning around 20k rpm at redline. I suspect it'll run around 17lbs on this little motor. I have a cathedral port lower intake from Magnuson on the way. Going to make an adapter plate for this blower and have an idler pulley mounted to the plate. I'm hoping to get 75% belt wrap on the pulley with the stock fbody accessory drive. Due to no intercooler, I'm going to spray a shitload of water/meth through the rotors.
                          Not much of a start, but hope to have everything mocked up on a friends motor within a month so everything is an afternoon bolt on. Total investment thus far between the blower, rails and lower intake is $780. Should be complete, even with injectors and pump for under $1500.
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            #58
                            Holy crap.
                            You work quick. And your build is awesome.
                            My previous build (currently E30-less)
                            http://www.r3vlimited.com/board/showthread.php?t=170390
                            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                            • bmk
                              • Feb 2011
                              • 598
                              #59
                              I've never weighed my piggy but damn 3100 with the iron block. I'm probably about the same with the only difference is the t56 vs th400
                              Worlds 1st LS powered e30 cabby.
                              Cab
                              billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
                              Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
                              Shaggin Wagon
                              : 01 325xiT 5 speed
                              91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
                              88 CRX OEM+ 42mpg DD.
                              • bmk
                                • Feb 2011
                                • 598
                                #60
                                I'm debating taking out the convertible top and just run it with no top or just the hardtop gotta save some weight right.... haha
                                Cab
                                Shaggin Wagon
                                : 01 325xiT 5 speed
