M62TUB44 to 318is wiring help request.
  • Yezus_Krys
    • Feb 2016
    • 80
    So my 318is I picked up came with a bad cylinder in the M42. I bought an M52tub28 but ended up getting a 99 M3 with low miles. So swapped in the S52 and got a chance to hear it crank but never actually got it running. I kinda rushed the swap too so I wasn't too excited about car. Now I have sold all engines and I have an M62b44 from a 97 540i 6spd.
    I am trying to figure the wiring but not finding much support.
    -Is it really worth it to use the M60B44 harness with the M62B?
    -Anyone has an ETM?
    -Who else has done this and how did you go about you wiring?
    Looking at the garages tics pin out I'm a bit confused on the terminals and relays location and identification.
    Yes I have searched and got much information on my S52 and M52 when I had them but all I'm finding is information on M60 which has me considering going with that harness.
    Sent from my iPad using Tapatalk
    Last edited by Yezus_Krys; 01-19-2017, 07:43 PM. Reason: Tittle as supposed to read M62B44
  • gart
    • Jul 2012
    • 295
    From my little reading on the m6x swaps most people use the m62 block with the m60 heads in our cars.
    89 325 cabrio in progress m52tub28 swap
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
    • jpod999
      • Dec 2015
      • 1401
      Read this: http://www.r3vlimited.com/board/showthread.php?t=246108
      ETMs: http://www.bimmerforums.com/forum/sh...)-For-Download
      Basically, since the car you got the motor from is OBDII and likely had EWS, it will be much more difficult to wire than going with an M60 OBDI harness. Not impossible, but much more difficult.
      OBDI M62B44/6 swap
      Transaction feedback
      - jpod999
      • delamaize
        • Nov 2013
        • 1460
        Just find a M60B40 OBDI motor, harness, and DMU. So much easier, and you still get that V8 goodness.
        Dumpster Fire Pilot
        • Yezus_Krys
          • Feb 2016
          • 80
          Well I do have access to an M60 with harness and DME however I want to work with what I already have. I've checked that list of ETMs and just like all the others I'm finding there's none specific for the E39 540i. I'd atleast want to scrub the right ETM.
          • jpod999
            • Dec 2015
            • 1401
            Here is your E39 ETM: http://www.bmw-planet.net/diagrams/r...9old/index.htm
            You can't use Chrome, so dig out Firefox!
            OBDI M62B44/6 swap
            - jpod999
            • Yezus_Krys
              • Feb 2016
              • 80
              Thanks!
              • Yezus_Krys
                • Feb 2016
                • 80
                Thanks. There's a bit more to the M60 setup than just the DME and wire loom from what I am reading. It'll be easier and cheaper to buy a harness adapter it seems.
