Herp de derp M60 in progress - track day complete
  • dasmanschaft012
    • Apr 2014
    • 642
    #106
    More as notes for myself:
    Change driveshaft bolts/torque
    Install and route O2 sensors
    Remove stupid X brace that hangs way too low
    Drain brake/clutch fluid
    Remove fill lines
    Remove HP lines
    Remove remote adjuster
    Remove pedals
    Modify stupid pass thru plate and run new uninterrupted fill lines
    Remove stock bias adjuster
    Reinstall is reverse of disassembly
    Registration
    New tires
    New hood
    check oil lines (eventually redo these again)
    buy and install guages/turner oil pan sensor peice
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
    • dasmanschaft012
      • Apr 2014
      • 642
      #107
      First REAL drive here. car is so fun. watch as i terrorize a local old lady
      [oo==OO==oo]
      • wworm
        • Dec 2016
        • 1719
        #108
        holy moly its so crazy hearing v8 sounds out of an e30. Glad you posted a vid. Not enough "first drive" vids on this forum lol. Maybe I'm just needy.
        1984 Delphin 318i 2 door
        • dasmanschaft012
          • Apr 2014
          • 642
          #109
          Here's another exhaust clip, I think it sounds really really good. currently working on the brakes again...
          [oo==OO==oo]
          • wworm
            • Dec 2016
            • 1719
            #110
            Yeah you mentioned the brakes being sketchy in the first vid, just because of no booster?
            • dasmanschaft012
              • Apr 2014
              • 642
              #111
              The whole garagistic/wilwood pedal/master manual set up is not "direct" bolt in. Not engineered great.
              Lots of us here are having problems getting the set up to work and perform decently.
              I just pulled all my pedals apart again to make a bunch of changes.
              [oo==OO==oo]
              • dougie30
                • Apr 2012
                • 1708
                #112
                is that 2.5 pipe all the way back?
                M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                • dasmanschaft012
                  • Apr 2014
                  • 642
                  #113
                  yes it is
                  [oo==OO==oo]
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5596
                    #114
                    brooooooooo my shop is right down the street from steve lol awesome
                    • dasmanschaft012
                      • Apr 2014
                      • 642
                      #115
                      steve is the bomb, he did a great job, and basically nailed it with minimal instructions. i didnt even draw him a picture he just did it right.
                      [oo==OO==oo]
                      • dasmanschaft012
                        • Apr 2014
                        • 642
                        #116
                        Change driveshaft bolts/torque - done
                        Install and route O2 sensors - done
                        Remove stupid X brace that hangs way too low - done
                        Drain brake/clutch fluid - done
                        Remove fill lines - done
                        Remove HP lines - done
                        Remove remote adjuster - done
                        Remove pedals - done
                        Modify stupid pass thru plate and run new uninterrupted fill lines - done
                        Remove stock bias adjuster - done
                        Reinstall is reverse of disassembly - done
                        Registration - done
                        New tires - getting some bottle caps with good tires today
                        New hood
                        check oil lines (eventually redo these again) - no leaks, fine for now
                        buy and install guages/turner oil pan sensor piece - need money
                        today:
                        bleed brakes and clutch
                        check for leaks
                        set clutch stop
                        reinstall steering column
                        test drive
                        final reassembly?
                        my goal is to get to a dyno day aboout 30miles away on the June 2nd. At this point, it just depends on brakes and getting a hood
                        [oo==OO==oo]
                        • dasmanschaft012
                          • Apr 2014
                          • 642
                          #117
                          Catching up on pictures
                          Exhaust pics
                          Put heat shielding on the clutch line and floor. ill probably bash this in some more later.
                          Foam tape to seal the rad to the core on the sides
                          Might as well use it all
                          Before:
                          Look at all that diff access
                          After:
                          Garagistic spare delete panel saves 4.7lb, not including hardware or paint.
                          sealed with foam tape. Pretty flush.
                          Removed Gargagistic X brace, i don't know how anyone can run this, its so low.
                          Pulled all this shit out
                          Got new hoses
                          Garagistic I hope youre reading this, cuz this plate thing sucks ass. Redesigned for better cable exits, and removing the stupid bulkhead barbs
                          Why buy new tires when you can just get some bottles for 1/3 the price?
                          Brakes work much better now, I think that a BBK/race pads will make it acceptable.
                          Many mods to the Garagistic set up but im getting it to fit and work better.
                          [oo==OO==oo]
                          • jpod999
                            • Dec 2015
                            • 1401
                            #118
                            I made my pass through plate like that, it also mounts the reservoirs.
                            OBDI M62B44/6 swap
                            Transaction feedback
                            - jpod999
                            • pondhopper
                              • Sep 2014
                              • 30
                              #119
                              Care to detail the mods to the brake pedal/mount/masters you made?
                              I will be adding a dash support brace to where the pedal adapter mounts to the dash to eliminate bending in the area when braking.
                              Would the problems be the same if you had used Wilwood over Tilton pedals?
                              Any more pics of the adapted piping pass thru? Tia
                              • dasmanschaft012
                                • Apr 2014
                                • 642
                                #120
                                Most of my changes have already been implemented in Garagistics latest version.
                                Cut the side out so the adjuster cable has room to swing. I opened it up a little more after this as well.
                                Then i ground back this edge to allow better tool access to the front bolt holes.
                                I dont have a good picture, i cut back the edge with red. I cut back about 1/2".
                                The last thing i forgot to do, is weld nuts to the rear mounting holes, this would make it SO much easier to install, and the brakes then become a 1 person job, except for putting the steering column back in.
                                No, the problem is the bracket not the pedals. The latest Garagistic bracket looks much better than the one I bought from them.
                                Ill try to get some later, the last 3 weeks have been non-stop last-minute-trying-to-make-it-to-events and I haven't stopped to take many pictures.
                                [oo==OO==oo]
