M62B44,M60B40 heads & cams, Eaton M112 (now with NOS)
  • Mykk540i/6
    • Oct 2014
    • 175
    #46
    It's Alive!
    It starts up, idles, runs and drives on the Speeduino EFI. It's obvious the amount of tuning I've got left to do, but it's getting there.
    • Mykk540i/6
      • Oct 2014
      • 175
      #47
      Video of the car running with the Speeduino:
      Other goodies have arrived, including the Jaguar Eaton to BMW heads &, idler & blower case mount kit.
      The cylinder heads are currently off getting rebuilt. But in the meantime I've started slowly piecing engine bolt on's back together.
      • george graves
        • 20003
        #48
        Originally posted by Matt-B
        • flyboyx
          • 8371
          #49
          what are the details about that intake adapter? that thing looks interesting. the blower stands up pretty high. I assume you will need to cut a hole in the hood?
          Gigitty Gigitty!!!!
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #50
            Where the F@#$% do you order that shit from?
            • Mykk540i/6
              • Oct 2014
              • 175
              #51
              The intake adapter kit is from a BMW forums member named Toolman. He's put together an extensive kit meant for the '99+ E39 M62's, I'm expecting a bit of modding and shaping to get the adapters to work for this application.
              • dmjensen
                • Jan 2011
                • 805
                #52
                I don’t remember from toolman’s posts, do you have to get the snout of the supercharger shortened to line up with our belts?
                Edit: Did you ever finish your research into the supposed m60b44 “high compression” motor everyone claims is created by putting m60 heads on an m62 block?
                Last edited by dmjensen; 03-28-2018, 05:26 AM. Reason: Thought of another question
                • Mykk540i/6
                  • Oct 2014
                  • 175
                  #53
                  You need to pull and flip the S/C pulley for it to line up with BMW pulley.
                  After my own measuring I've determined that the M62 short block with B40 heads will make 9.94:1 static compression. The folks who assumed 11:1 with B40 heads didn't realize the difference was in the piston height & piston dish volume not in the cyl head chambers....at least not in the engine parts I've found and torn apart to use for my build.
                  • dmjensen
                    • Jan 2011
                    • 805
                    #54
                    So the compression ratio is slightly lower then a “stock” m62b44?
                    Are you using the m60 camshaft then too? I’ve read in several places they have a higher lift then the m62 did. I’m curious if it’s possible to put the m60 chain set up in an m62 just for the sake of having a more reliable set up. Also if it would be better to use the stock m62 block and heads but install the m60 camshafts.
                    • Mykk540i/6
                      • Oct 2014
                      • 175
                      #55
                      B40 heads & cams on M62 with M60 double roller timing set up.
                      • dougie30
                        • Apr 2012
                        • 1708
                        #56
                        i may have missed it, but what will you be doing for the supercharger belt drive? crank pulley adapter of some sort id assume?
                        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                        • Mykk540i/6
                          • Oct 2014
                          • 175
                          #57
                          You flip the supercharger pulley around it lines up with the M60 crank pulley. So you use a longer 7 rib belt to get to s/c
                          • Mykk540i/6
                            • Oct 2014
                            • 175
                            #58
                            M60B40 cylinder heads back from the machine shop. I've now got everything needed to assemble the engine. Super stoked.
                            • Mykk540i/6
                              • Oct 2014
                              • 175
                              #59
                              (I know I need to clock those cam gears before assembly)
                              • Mykk540i/6
                                • Oct 2014
                                • 175
                                #60
                                Locking in the cam phasing and cam gears, does this look correct to you guys:
                                With cyl #1 @ TDC, installed cams with lettering facing out and locked in place with cam blocks. I've set up the cam gears to be in the middle of adjustment slot, The main cam drive gear has the arrow pointing up following spark plug angle.
                                Cam lobes of cyl #1 TDC of compression stroke:
                                Cam lobes of cyl#6, TDC of exhaust stroke (cyl#1's paired cylinder)
                                The timing chain fits right set up like this and with timing blocks in place I've maintained the middle of the adjustment slot mounting for the gears.
