How to connect an oil cooler, M60
  • obetten
    • Jan 2018
    • 5
    Hello. Connecting the oil cooler between the outlet from the oil pump and the oil filter, is that the right way?
  • dasmanschaft012
    • Apr 2014
    • 642
    no, you want the cooler AFTER the filter so particles dont clog the cooler.
    also, make sure you run a thermostat or else itll take forever to warm up.
    We're in deep now boys
    1988 325i SETA - Daily driver
    1988 340iL - Track car
    My M60 V8 swap thread here
    [oo==OO==oo]
    • obetten
      • Jan 2018
      • 5
      make sense :) But why are people blowing up their coolers on their m60`s?
      • dasmanschaft012
        • Apr 2014
        • 642
        I haven't heard of that before? Most M60 in the US didnt come with coolers.
        Only "arid climate" cars got coolers and a cooler thermostat (Middle East)
        [oo==OO==oo]
        • The Dark Side of Will
          • Jun 2010
          • 2796
          Counterpoint:
          The last thing the oil should go through before it goes to your bearings should be the filter.
          • obetten
            • Jan 2018
            • 5
            Originally posted by The Dark Side of Will
            Counterpoint:
            So you would say that the cooler should be between the outlet of the pump and filter?
            • dasmanschaft012
              • Apr 2014
              • 642
              Counterpoint:
              I take my opinion back I like this more. TBH, either is probably ok but this sounds like a more desirable feature.
              [oo==OO==oo]
                • Jun 2010
                • 2796
                Right. Oil should go from the pump to the cooler to the filter and into the engine.
                • obetten
                  • Jan 2018
                  • 5
                  I connected the oilcooler after the oil filter. Reason: Hot oil flows better trough the filter. But the cooler blew up and i dont understand why?
                  • jpod999
                    • Dec 2015
                    • 1401
                    Aftermarket or oem M20 cooler?
                    OBDI M62B44/6 swap
                    Transaction feedback
                    - jpod999
                    • obetten
                      • Jan 2018
                      • 5
                      both aftermarket. on of them was rated 500psi. edit: yes, i blew up two of them
                      • jpod999
                        • Dec 2015
                        • 1401
                        JGood has nothing but issues with aftermarket oil coolers. Eventually just got rid of them.
                        OBDI M62B44/6 swap
                        - jpod999
                        • JGood
                          • Jan 2004
                          • 7959
                          Save yourself some time and money, just go buy a few gallons of oil and dump it all over your engine bay and underside of the car. Same result as installing an oil cooler on an m60 e30.
                          I have no idea why they constantly blow oil coolers (and standard spin-on filters, if you decide to make two bad decisions in a row, by converting to that as well). I gave up prior to figuring it out. The last straw was when a filter blew, covering my passenger front brake disc in oil, causing me to do a 360 on the highway when I hit the brakes, missing my buddies e39 M5 by a few feet, and somehow not flip as I slid through mud sideways.
                          e30 restoration and V8 swap
                          24 Hours of Lemons e30 build
                          • dasmanschaft012
                            • Apr 2014
                            • 642
                            I'm about to switch to a spin on adapter. should i be worried :(((((
                            i also have a cooler im plumbing in (Setrab)
                            [oo==OO==oo]
                            • JGood
                              • Jan 2004
                              • 7959
                              Both Ryan and I tried using the spin on filter adapters. My first adapter leaked from the middle of the casting as soon as I fired the car up. After replacing it, I got pin holes in every single oil filter I installed. Ryan did as well. I built an enclosure around mine to eliminate the potential from external impacts. No difference, so it was happening from the inside out. My best guess was cavitation, but I really don't know. Then Ryan and I both went through 3-4 various oil coolers, all would randomly explode, leaving the car sitting on the side of the road, luckily not blowing up the engine as we both ran oil pressure gauges and caught it in time each time.
                              I'll never use an aftermarket oil cooler/filter setup on a street car again. The factory stuff works 100% perfectly. It almost cost me my car/life when it hit my brakes at highway speed.
