91 318is/ LS Swap
  • didithepest
    • May 2017
    • 45
    #31
    wow amzing
    • sgtskid
      • 763
      #32
      The dash looks really good. Nice job!
      Current: '91 DS M3, '03 TS M3 (6MT)
      '06 Chevy 2500 Duramax - Race car hauler, '90 Corvette - Weekend toy
      Past: '88 AW M3, '87 RB M6, '98 CS M3, '88 DS M3, '88 Zinno M3, '88 AW SETA (facelift),
      1988 Super E (Bronzit - grey wrap)- RIP, 1986 353, 1986 VW Jetta (vr6) - Racecar
      IG: RDE_Fabrications
      Check us out
      Or YouTube --> HERE;
      • TeXJ
        • 1914
        #33
        which grit of sand paper did you use and was that just regular body filler?
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
        • Tubesock
          • Jan 2019
          • 42
          #34
          I used 80 grit the whole time. I’ve read about people going from 80 all the way to 220 but I knew I was putting texture coating on it that would bond just fine. I used regular ole Bondo body filler because from everything that I’ve seen and read the padded dash filler is not worth it.
          • TeXJ
            • 1914
            #35
            Thank you! I've been looking into a way to do this with mine.
            1990 325is
            m52b28
            3.73lsd
            • Tubesock
              • Jan 2019
              • 42
              #36
              Anybody have experience with cam swapping an L33? I’m debating between a stock LS3 cam and a sloppy stage 2 cam.
              • Pootis
                • 636
                #37
                That is a very large cam difference lol
                1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                • Supadave
                  • 1006
                  #38
                  Whats the plan? turbo? NA?
                  https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                  • Tubesock
                    • Jan 2019
                    • 42
                    #39
                    N/A
                    • Supadave
                      • 1006
                      #40
                      N/A
                      HP goal? Max RPM? Are you going to upgrade the valve train? Because the stock springs will limit you.
                      • Tubesock
                        • Jan 2019
                        • 42
                        #41
                        400 wheel, 6500 RPM and I’m upgrading to PAC 1218s regardless which can I go with.
                        • Supadave
                          • 1006
                          #42
                          Stage 2 Sloppy
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            #43
                            The rotating assembly will go to 7000 with ARP rod bolts.
                            • Pootis
                              • 636
                              #44
                              Sloppy Stage 2 for sure. That is what I will be running in my 6.0
                              • Tubesock
                                • Jan 2019
                                • 42
                                #45
                                Behold the 5.3 L33 out of an 06 Silverado 1500. Aluminium block to keep the weight down, 799 heads for good air flow, and a sloppy stage 2 cam enroute.
