Lower Control Arm stuck!
  • AmosCake
    • Feb 2021
    • 218
    Doing a suspension refresh but the control arm is stuck to the subframe. Any advice?
  • roguetoaster
    Biggus Tippus
    • 7830
    Hit it from the bottom until it falls out, you can also add leverage while hitting to make it pop.
    • Vincenze
      • Apr 2019
      • 1042
      You need a fork.
      Hammer it in.
      https://www.harborfreight.com/automo...tor-63519.html
      • AmosCake
        • Feb 2021
        • 218
        I’ve been hammering at it with a fork and it would not budge
        • AmosCake
          • Feb 2021
          • 218
          this was the first method I did before buying the fork and they both haven’t worked.
          • Vincenze
            • Apr 2019
            • 1042
            Then you have to use PB Blaster from the top a few times and wait for a day.
            Maybe, you can hit the bolt from the top, but the access is very bad.
            • roguetoaster
              Biggus Tippus
              • 7830
              The stud rusts in the bore and sticks, it's just something you have be persistent with. In some rare situations you may be able to tighten the nut beyond normal and break it free, but you risk deformation and sticking the assembly in place. You also may be able to get a socket that fits over the threads with no nut and hammer on that from the top, but the angle stinks and with lots of extension the impact is lessened.
              • AmosCake
                • Feb 2021
                • 218
                Yeah I’m scared of deformation. I might do what Vince suggested and soak it with PB blaster and what’s your suggested to hammer the top. Although I have tried hammering the top, maybe the pub blaster will loosen it.
                • AmosCake
                  • Feb 2021
                  • 218
                  Update. PB Blaster with some hammering did not work. Control arm still very mush stuck. Next method will be using a 8 pound sledgehammer
                    • 34844
                    I don't know if this works on RWD E30s - but on my ix, I put a short socket on top, with the nut threaded to the top of the ball joint, and hammer it from the top. It's way easier and I don't have to crawl under the car. You have to remove the airbox to do the passenger side but that only takes a couple minutes.
                    Fuck hitting ball joints with a hammer. I have never, ever had that work once in my life.
                    • AmosCake
                      • Feb 2021
                      • 218
                      This was the first method we tried with no luck. It doesn’t budge
                      • AmosCake
                        • Feb 2021
                        • 218
                        Final Update! I hammered the joint at a different angle and it literally just slipped out as if it Wasn’t stuck. Hammering the ball joint all around was the only method that worked for me. Thanks
