No Start Issues
  • Sreihg
    • Feb 2022
    • 11
    Originally posted by It's Soda Not Pop
    put a 15a fuse in #11. check that fuse again and see if it popped. Also check your Main relay
    the fuse is still fine, hasn’t popped. I will see if I can obtain a 15a fuse though. Relay is clicking when trying to start, so I’m thinking it’s fine. One thing though is that if you crank it for about a minute, it will backfire through the exhaust. I’ve read this could be excess fuel or timing is off?
    I also tried to check resistance on CPS terminals but I wasn’t really able to get a reading. I tried checking voltage too but nothing. Maybe it’s my meter, or maybe it’s bad. I ordered a parts store one to temp swap it out with to see if maybe that’s a cause.
    • It's Soda Not Pop
      • Jan 2022
      • 875
      I feel for you man. I had this no start issue back last year. And it was a PITA. Like I said mine was Main relay, alternator, and fuse. But yours could be a CPS issue or maybe spark. Is it throwing any codes?
      I know this kind of a lazy way to fix a problem, but after I got my problem resolved I replaced every sensor and relay again. I did it to make sure it was good.
      88' Seta 2.7i Zinno
      https://www.r3vlimited.com/board/for...430-my-88-seta
      • Sreihg
        • Feb 2022
        • 11
        well, I think the parts store CPS resolved one issue. CEL is no longer on when I turn the key and try to start it. Still, it doesn’t start. I don’t blame you for replacing parts, anything to help avoid this issue again.
        my issue seems to be spark at this point. I pulled a plug and held it against the valve cover, and no spark when cranking. Time to do some digging on this
        • It's Soda Not Pop
          • Jan 2022
          • 875
          How old is the Rotor and Cap? How old is the Ignitor? Plugs and wires?
          88' Seta 2.7i Zinno
          • Sreihg
            • Feb 2022
            • 11
            Oof, probably a decade or older.
            • It's Soda Not Pop
              • Jan 2022
              • 875
              Might be time to replace all those items. I would for peace of mind.
              88' Seta 2.7i Zinno
              • Sreihg
                • Feb 2022
                • 11
                Did some more troubleshooting this week. I’m seeing about 12v power at the coil. Grabbed a spare spark plug and used the lead from the coil to distributor to check for spark - and there it was. Double checked spark after going through the distributor again, still nothing. So must be something there. Need to budget out for more parts lol
                • Sreihg
                  • Feb 2022
                  • 11
                  Well, I replaced the distributor cap and rotor. Spark is going through the coil wire, but not to the plugs. Could I have got a bad rotor/cap? Would the distributor be bad somehow?
