Fan Clutch Question
  • e30rik
    • Mar 2014
    • 84
    Fan Clutch Question
    I'm doing my first timing belt job (started today, didn't finish). I removed my fan and it's clutch but I think I made a noob mistake. I left the fan laying on it's side as I was working and it stayed there the whole day. I just now leaned it up until I finish the job tomorrow. My question is did I likely ruin the clutch and how can I test it?
  • slippery
    • Nov 2011
    • 375
    Newspaper test?
    • zaq123
      • Jul 2016
      • 1515
      Originally posted by slippery
      Newspaper test?
      what he said. chances are your clutch is 100% ok if it was ok to begin with.
      • e30rik
        • Mar 2014
        • 84
        Looks like it’s shot. I rolled up a magazine and stuck it in the blades after driving for 30 minutes. Stopped the fan pretty easily. Fan also spins too freely when the car is cold/off. I also have a whirring noise after doing my timing belt. Hoping it’s one of the drive belts or the fan but it’s probably the tensioner…
        • peytonracer4
          • May 2011
          • 524
          why would laying it down damage it?
          • digger
            • Nov 2005
            • 6143
            are you sure you got it hot enough?
            • e30rik
              • Mar 2014
              • 84
              Read something about the fluid draining out and the clutch won’t operate properly. I ended up just buying a new one. The new one has quite a bit more resistance, should be good to go now.
              • peete
                • Apr 2007
                • 75
                I'm pretty sure that's an old wife's tale. How long do those things sit on parts distributor's shelves laying down?
