86 eta cps and speed sensor replacements
  • Kozworth
    • May 2011
    • 1339
    Can someone send me a link to the two crank sensors in the tranny bell housing? I’m only seeing black crank sensors, some websites say they are both the same part no in bell housing. Other sites says it’s in the upper timing cover. Just getting confused and want to order the right part
  • reelizmpro
    • 9558
    They are all on the bell housing on the ETA's. 2 are the same.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Kozworth
      • May 2011
      • 1339
      Ok I was curious if they are different sensors. Same sensor in two spots. Was getting confused by black and gray plug if there was a specific sensor for each one. Thank you
      • reelizmpro
        • 9558
        It's been over 25 years since I've had my ETA but the M3 uses the same setup. Since the connectors are identical, BMW used colored bands or zip ties on the ends so you don't get them mixed up causing a no start condition. This may be why some are different colors.
        88 M3 - LACHSSILBER
        • jbontke
          • Mar 2019
          • 449
          I used a silver sharpie to mark the plugs so I didn't get them mixed up. Otherwise, they are interchangeable.
          • tomstin
            • Mar 2015
            • 570
            The sensors are the same, their position and where they plug into the harness are specific.
            2004 525i Manual - 1985 325E Coupe Manual
