5 spd final parts list.....
  • e30 gangsta
    • 3877
    with the help of my friends rwdrift and digitalwave im gonna attempt my 5spd swap. Im getting all the parts off a 325is. I wanna rebuild as much as i can while im under there... so my question is... is there anyhitng else that i need???
    bav auto clutch kit
    new shifter bushings
    flywheel resurfaced by a machine shop and lightend
    shift boot and knob
    manual tranny mounts
    redline mtl
    redline diff fluid 75/90w
    flex disc bolts
    new flywheel and pressure plate bolts 6 of them with self locking nuts.
    plus all the stuff i get off the 325is.... and drop it into my 89 325i
    any help would be appriciated.
  • e30 gangsta
    • 3877
    dont everybody post @ once now..... im having problems finding prices for some stuff does bma have everything???
    • Bill 84 318i
      • 1600
      Not everyone is posting because it's been gone over a few times in this forum.
      BMA should be able to get you anything that has a part number.
      • e30 gangsta
        • 3877
        looked on bma with the search function.... found some stuff.... now im looking for part #'s
        • BS87
          • 1606
          • e30 gangsta
            • 3877
            yeah the etk is down i think.... but here is what i have so far what yall think??
            Bma Auto Parts
            Flex disc 26.09 BM041986
            Center support bearing 18.71 BM070974
            Master cylinder 38.37 BM039571
            Boot 9.18 BM017430
            Tranny mounts (2) 18.16 BM017361
            Total 135.86 with specE30 coupon code….
            Bav auto
            Clutch kit 234.95 (includes pilot bearing)
            Pressure plate bolts (6) 7.50
            Flex disc bolts (6) 11.70
            Flex guibo nut (6) 5.70
            Redline mtl (2 qt’s) 17.90
            Redline diff fluid (2 qt’s) 17.90
            Shipping 16.95
            Total 312.60 shipped
            Total with everything above… $448.46
            All I need now is
            Shift linkage
            Clutch hydraulics ( hoses etc etc… )
            Flywheel resurfaced by a machine shop and lightened
            I got the slave cylinder already
            If anyone can help me find out were I can get the linkage and the hydraulics stuff please let me know… also if im missing anyhting do me the favor and tell me!!!! thanks....
            • trent
              MAKE SURE U INSTALL THE DORITO BEARINGSSSSSSSS
              • aaron_silva
                • 1785
                You can get the clutch kit for cheaper at www.gripforce.com. I have never tried them though.
                $178 for...
                SACHS Pressure Plate
                SACHS Clutch Disc
                Release Bearing
                Pilot Bearing
                Alignment Tool
                Aaron
                • Rob
                  • 8166
                  ok, r3v, bimmerforums, dtmpower, where else did you post this?
                  BEERTECH
                  • mpower318i
                    • Oct 2004
                    • 73
                    about the swap
                    obviously you need all the clutch hydrolics and you also need and ecu becuase you have an auto ecu....but there is a way to fool that at least it is on a 240sx..... the wiring might be diffrent i'm not sure of how it all works from a 5sp to an auto in a BMW but i know that in an jap import you need a 5sp ecu and sometimes the wiring is diffrent and you also need all the parts from a 5sp vehicle i.e tranny mounts/crossmember, tranny itself, clutch kit, the flywheel you can resurface at a machine shop.....how you know what machine shop just ask around town to the performance shops and see who the best is! ummmmm don't forget to bleed the clutch or your tranny will hate you from then on. Also get stuff from the source of the tranny that you don't think you need like lines that are connected to the clutch hydros and brackets etc becuase you never know what you might need part numbers I don't know but that's the basis for getting the swap done, oh and don't forget to by all the fluids you need. the best gear oil i have used is penzoil synchro mesh it's good on tranny's that have lots of miles and it helps the syncros from going bad at that age and that amount of miles. Also it helps reduce wear on the syncros especially if you like to snatch gears and just give the tranny hell. don't forget the shifter and the center panel. the panel is diffrent from the auto panel and of course you'll get the shifter with the tranny.
                    • e30 gangsta
                      • 3877
                      thanks man but im getting most off the stuff of a parts car.... and yes i post w.e. i can get a answer...
                      • James Crivellone
                        Head Janitor
                        • 6305
                        You don't need a new ECU, and the "wiring" is splicing 3 wires, the Parking Starter Disable and the reverse light
                        • Digitalwave
                          is a poseur
                          • 6299
                          Re: about the swap
                          Please don't post on topics you don't know about. The ECU does not need to be changed.
                          Rob, its on ever drift forum he posts on as well. And he has asked everybody that he knows on AIM too.
                          RISING EDGE
                          • e30 gangsta
                            • 3877
                            yeah i a noob and im sorry if this pisses you guys off my fault... and once again i thank everyone for there help / patience.... if this thread is by anymeans not usefull delete it....
                              • 34839
                              TJ, did you need the panel that's under the steering wheel from a 5 speed? because mine already has the space for a clutch. I just thought that was odd. I can't wait, kansas-ix is working on getting the 5 speed from his wrecked ix out for me right now :)
