Idle Air Control Valve Constantly Buzzing
  • SpencerL
    • Nov 2022
    • 5
    I have a 1990 325i. I was wondering why my ICV is always buzzing even when the car is off. I am having to unplug it when I am not drive it. Any ideas?
  • It's Soda Not Pop
    • Jan 2022
    • 865
    Break out the multimeter and find the wire that is still getting 12v when the car is off
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • ForcedFirebird
      • Feb 2007
      • 8300
      The white 5 pin relay most likely has a short. It's located next to two orange relays on the driver side strut tower, under a little black box (if still present).
      To test, just pull it out. If the ICV stops buzzing then that's it.
      john@m20guru.com
      Links:
      • It's Soda Not Pop
        • Jan 2022
        • 865
        If it's that relay mentioned above. Pelican has them. Don't use a brand you find at Autozone(or insert any auto parts store). I found out the hard way about relays.
        88' Seta 2.7i Zinno
        • SpencerL
          • Nov 2022
          • 5
          If the main relay was working properly and you pull it out then the ICV would turn off anyway. I do not think that my main relay is bad.
