Issue: Power moon roof will not open (no movement, so motor sound, nothing) It was working and then all of a sudden it was not.
So I am guessing that there are the following components related to the moonroof. Below are the steps that I have taken to troubleshoot. Let me know your thoughts on resolving.
- Fuse - checked and its good
- Wiring from fuse box to Switch - have not thoroughly inspected the entire line
- Switch - Not sure how to test, but currently suspect as root cause
- Wiring from switch to motor - have not thoroughly inspected the entire line
- Motor - removed and had another shop test and it worked fine
- moonroof mechanism - Cannot open to inspect
