Cooltant level at T-stat housing
  • Rosica
    • Jan 2004
    • 240
    I am replacing my ECU coolant temp senor this weekend, what I want to know is, how much, if any, coolant do I need to drain so when I pull the sensor coolant doesnt drain all over my engine?
    Also, can I remover the radiator to T-stat housing hose at the housing whithout draining? Aleast then I can see the sensor and how much I need to drain.
    07 335xi Sport
    00 S2k
    01 A4 1.8t-Sold
    88 M3-Sold
    91 325iC-Totaled
    89 325iS - Sold
    87 325-Totaled
  • Jon325i
    • 6934
    Regardless of how careful you are with this job, you will spill some coolant. Probably not a lot since the t-stat is at one of the highest points of the cooling system so lost fluids should be minimal. Either way, you will have to replace the lost fluid and bleed out the air as needed.
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
      • 34847
      while on this subject (not to steal the thread), how about the throttlebody coolant gasket? Mine has a pinhole leak I'd like to fix before winter. I need to flush the coolant anyway but it would be nice if I could do that on a seperate day without spilling coolant everywhere.
