Right turn signal not working
  • christophersan
    • May 2024
    • 1
    Hi, I just got a M20B20 ‘90 E30 and I got some issues and questions. I noticed that my right side turn signal will flash extremely fast on the dash and won't flash green, going outside I noticed that both front and rear are not working, left side works normally. I would have suspected the bulbs but turning on the hazards lights all of them up. Is there a relay or something under the hood or column that I can acces and clean?
  • 82eye
    • Jan 2009
    • 2108
    it'll be a bad bulb or one not making contact. time to clean all your sockets.
    • reelizmpro
      • 9558
      Yep. Pull the right front bulb, clean the base and the contacts in the housing. Obviously, make sure the bulb is good and looks good first. Most of the time it's just a bad connection though.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • mgarzaron
        • Oct 2024
        • 1
        Hi, I have a similar problem: the right turn signals work fine when to headlights are off. When the headlights are on (light switch pulled out to on position) the right turn signals don't flash, and the right turn arrow in the dash stays on. I checked bulbs, which are not the issue, and I also replaced the light switch. Issue still there. What could be the reason? Appreciate your insights
