83 323i with a M30 swap starting issue when hot...
  • Bourkeco
    • Jun 2024
    • 5
    I have a new to me 323i/M30. The issue is when its cold it will start like clockwork and runs and drives perfect. I can restart it a dozen times until it warms up, then no crank. Any ideas what it could be? Im sure its a sensor or something but which on should I start with?
  • Bourkeco
    • Jun 2024
    • 5
    Update! so I did the same thing yesterday and wanted to try it again before i made it a symptom. Started the car in the morning 4-5 times cold no problems.... Left it in the sun And No crank in the afternoon (after it sitting in the 100f sun,, Im leaning toward Crank Position sensor.. Any thoughts?
    • tomstin
      • Mar 2015
      • 568
      I'm not familiar with the M30 but with a no crank issue, start with a multi-meter, do you have 12 volts at the starter? When you turn the key, do you get 12 volts at the solenoid? The crank position sensor tells the ECU the engine speed which it needs after it cranks.
      2004 525i Manual - 1985 325E Coupe Manual
      • mzollo
        • May 2012
        • 120
        is this a car with a dual pump system? I had this issue when my in tank was dying and the external was doing all the work. long starts hot, starts fine cold. id check there. mine stayed like this for years though
        • e30davie
          • Apr 2016
          • 1788
          air leaks can give a lean condition, which are compensated when cold with the cold start enrichment, but when hot it wont start as its too lean. one thing to look at perhaps.
          • Bourkeco
            • Jun 2024
            • 5
            Appreciate the input It is a No Crank issue when warm/hot Not a crank no start... Th starter solenoid is not getting the 12v signal to start...
            • TobyB
              • 5263
              Have you confirmed that you can jump 12v to the solenoid terminal and get it to crank when hot?
              Then you just needa meter, and some diagrams:
              because the M30 starter motor ought to be wired the same as an M20 starter motor.
              I have a 40a push button switch and a couple of gator clamps I use to answer just these sorts of questions.
              I have found that the Botch starters on BMWs tend to get sticky solenoids when hot...
              t
              • tomstin
                • Mar 2015
                • 568
                Okay, looks like you're on to something. The wiring diagrams are critical. As these cars age, wiring connectors start to build resistance and relays are tired. As mentioned above, use a jumper wire to see if you can activate the solenoid. Of pull the starter and bench test it hot. If that all works, in the wiring diagrams, work your way back up from the starter solenoid. Clean the contact pins on the relays wouldn't hurt. Unfortunately, only failing hot makes this diagnosis a bit more difficult. Good luck!
                • Bourkeco
                  • Jun 2024
                  • 5
                  Ok I believe I solved the issue. It was simply corroded connections that would lose continuity when hot.. Not very exciting...LOL Thanks everyone for your input!
