no dash lights
  • grumpygit
    • Nov 2024
    • 25
    no dash lights
    new problem, I have no dash lights, when I put the headlights on the dash is just dark, is this an easy fix?
  • ehrawn
    • Aug 2023
    • 206
    Do you mean the gauge cluster or all of the indicator lights throughout?
    • grumpygit
      • Nov 2024
      • 25
      I mean the gauge cluster, my electric window buttons light up,
      • zaq123
        • Jul 2016
        • 1515
        once pulled, turn the headlight knob clockwise (the plunger thingy) and do it when dark out. Still no lights on the cluster?
        • ehrawn
          • Aug 2023
          • 206
          yes. first things to check are that you haven't dimmed the gauges and secondly that you haven't blown a fuse.
          • CMG
            • Apr 2008
            • 736
            You can also try whacking dashboard above the gauges.
            • reelizmpro
              • 9542
              Check the dimmer on the headlight switch by rotating it clockwise for full ON, counter clock wise for dim. Try rotating it back and forth to see any change. Do this in the garage or at night so you can see what's going on it. Many times it's just the potentiometer in the headlight switch.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
