Dinan vs. JC chips
  • Brew
    • 3060
    Originally posted by eightyfoure
    el oh el.
    If I were to thow on a chip on an eta, can I just expect a few hp? Could it change the rpms enough to make it use the engine a little more then an average eta would?
    A good chip (JC) for your eta would make a very noticeable difference.
    '91 318is
      • 34844
      Originally posted by DanGillan
      or the other 30 times i've worked on cars in the past week at my shop job... i think i know my shit, i dont knwo anyone who unplugs their battery to swap a chip.
      you also don't know anyone who uses a torque wrench to put their wheels on, and look where that got you. sorry dan...
      • DanGillan
        • Mar 2004
        • 4061
        ok, that was before shop job started.... i knew it was better but didnt have the tools, lets get over this.... seriously...
        Dan
        • BlackE30
          • Sep 2004
          • 605
          I have a bav auto chip, I didnt really notice anything but there was a slight gain in the upper rpms from around 4,200 or so to redline. I would only buy a chip if you can find a good deal on one. I got mine brand new for 110 shipped.
          • MarkD
            • Sep 2004
            • 488
            Well I can't offer you one for $110, but then you didn't notice a difference with that chip. Ask Rob Heeter if he likes the 93 octane chip he recently bought. I can arrange a group buy if some of you are interested.
            MarkD
            URL: www.dsylva-tech.ca
            • rwh11385
              lance_entities
              • 18403
              Whoa, I kinda noticed how I used to not be able to kick the rear out as easily in the dry.....but now I can. :twisted:
              And when cruising in 2nd @ 20-25.....it's a whole lot easier to smash it and get up to 4K or so.....where the real fun starts. Before, it was slower to react.
              • brodee
                • Jan 2004
                • 2914
                Originally posted by bimmerphile
                thats well within the error for the dyno ain't it?
                Yes it is, but with everyone telling me that the JC chips are SO much better than Dinan I didn't expect them to be this close.
                Originally posted by Jordan
                With the Dinan chip in my car I couldnt tell any difference what so ever (besides increased redline)
                Actually after installing the JC chip it FELT much faster, but the dyno proved that feeling wrong. I've come to not trust the butt dyno over the years, I like the real proof.
                Originally posted by rwh11385
                Still, the Dinan was tuned for WOT, so the peak #'s might not be that different, but the partial throttle is very different between the chips, but I wouldn't be surprised when the dyno comes back right to see the JC a better chip overall.
                Actually the JC chip was below the Dinan across the board. It stayed fairly even just lower at all rpm.
                how long did you give the ECU to recalibrate? when you first start it after swapping chips (and disconnecting the battery, rriiight!?), the ECU starts out with a default map and tunes from there.
                As stated it was in there for 8 days, including about 280 miles and an autocross, so I think it was sufficiently mapped. Also, yes, I disconnected the battery first, I always do before electrical work, doesn't take that long.
                Originally posted by Rob
                back to back plots would be much more accurate, IMHO
                Me too, that's why I will be running them, as stated.
                MarkD
                I plan on getting one of Mark's chip for my car once I get the rest of things ironed out.
                "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                1988 M3 - Track Rat
                1989 325iC M50 Vert
                1989 325i Coupe
                1991 318is
                1995 318ti Club Sport
                2006 330i e90
                2008 Tundra Crewmax
                • Rob
                  • 8166
                  dynoing mods :up:
                  rob not reading :down:
                  BEERTECH
                  • rwh11385
                    lance_entities
                    • 18403
                    Not the rev range below peak, but rather the power at partial throttle....which wouldn't be tested on a dyno.
                    The mapping for JC and Dinan should be somewhat similar at WOT, but what's good about JC (and Mark D) is the advanced timing and shit at partial throttle, so you have a power increase when not completely gunning it.
                    Also, if your engine is not tuned properly, it won't be making the power it should be. The tune of the engine, and the maintence that needs to be done or fixed is as important as the mods sometimes.
                    If the JC chip changed up the mapping or fuel or something from the Dinan and the engine is not running quite right.....it will not be making the power it should, at peak, or elsewhere. If you get the A/F ratio worked out, then hopefully the power will be better at peak, as well as across the board.
                    Well, that's what I can try to say with the limits of what I really know, but hopefully that is pretty correct.
                    • Rob
                      • 8166
                      i'm just glad people are actually dynoing instead of assuming what 'feels' fast
                      BEERTECH
                      • brodee
                        • Jan 2004
                        • 2914
                        I'm going to start using my g-tech to test against the dyno also. I know it isn't as acurate as a dyno, but it is consistant so I can make smaller changes and see if what they are doing in between dyno runs.
                        I'm also lucky to have a great BMW show here with a dyno. For anyone in or around Houston I would recomend you making a trip to http://www.bavhypersports.com/ and talking to Joel. He's been a huge help working with me on all this.
                        1988 M3 - Track Rat
                        1989 325iC M50 Vert
                        1989 325i Coupe
                        1991 318is
                        2006 330i e90
                        2008 Tundra Crewmax
                        • Rob
                          • 8166
                          dynojet?
                          BEERTECH
                          • brodee
                            • Jan 2004
                            • 2914
                            dynojet?
                            Yes Dynojet 248c
                            1988 M3 - Track Rat
                            1989 325iC M50 Vert
                            1989 325i Coupe
                            1991 318is
                            2006 330i e90
                            2008 Tundra Crewmax
                            • Den
                              • Mar 2004
                              • 162
                              Horsepower sells, so the manufacturers get all they can using far more advanced technology than any little company could ever dream of.
                              Manufacturers also have a world of issues to worry about, like CAFE, fuel quality, and idiot customers.
                              80's era BMW's were detuned a bit for the US market. This doesn't mean that a chip will make one run like a Euro car; they also has no cats and a higher compression ratio in many models. An extreme example would be the M30 in the E28 535i. 182hp in US trim. ~210hp in Euro trim. Anyhow, the point is that manufacturers do not always give you as much power as they could just because it would sell more cars.
                              • Den
                                • Mar 2004
                                • 162
                                MarkD
                                Yes, let's talk about that.
