Fuel starvation after high-lateral right handers when tracking
  • rogerscgreg
    • Mar 2026
    • 20
    I took my '87 E30 out to the track yesterday. It ran well until I ran into a fuel starvation issue mid-session. A few seconds after most right-handers, the engine would become starved for fuel and run dry for 2-3 seconds before returning to normal operation. The tank was about 75% full when it started happening. If I was well below half a tank, a simple lateral fuel slosh starvation issue might be the root cause, but I'd still be surprised. With as much fuel as the tank had when it started, I believe there is something more serious afoot, but I'm not sure what or how to further test it.
  • TobyB
    • 5291
    Early tank with the metal crossover line, right?
    I'd pull the pump out of the tank and see if you can see anything
    down there, from rust to water to a loose 'wet sump' cup around the pickup.
    Do you have the double pump arrangement, still? If so, your lift pump
    might be having trouble.
    I run an early tank with a late 318is single pump in it, and can reliably run down
    to a couple of gallons without starvation. But I'm slow.
    t
