Pulling m20b25
    • 37833
    Pulling m20b25
    I'm pulling the motor on the 91 in a week or 2 and am wondering if the motor and trans can easily come out together as a whole or if it's worth it to seperate them first.
    Thanks.
    Grover Beach, California
    BimmerHeads.com
  • hella 325
    • Sep 2004
    • 380
    I pulled my m20 as a whole no prob, remove the shift linkage from tranny. I didnt have the AC in mine not sure if the ac condenser will get in the way. (easier if you take PS pump and bracket off too)
    Russell
    1987 325is
    1992 240sx coupe
    1994 525i
    • UNHCLL
      • 8790
      i split my engine & tranny upon removal. You could do it as one whole, but you'll have to pull the radiator and take the hood off.
      Below the radar...
      • hella 325
        • Sep 2004
        • 380
        Yea forgot about removing the hood. i assumed you would ull the radiator first as well... seperating can be a pain as the tranny torx bolts can be a real pain to get to....and break free...
        Russell
        1987 325is
        1992 240sx coupe
        1994 525i
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          i've done both. some say its easier to pull the motor + tranny out, but this last swap i did, i had the motor in/out in a weekend.
          • bimmerlover
            • 424
            I've found it much easier to separate the engine and tranny first.
            • rs4pro3
              • 5808
              If you have a good Load leveler, the Engine and tranny can be pulled as one unit. in the 5-6 I've pulled, I've seperated 4 times, cut out the front core support and pulled the engine and tranny straight out, and pulled the Engine and tranny out together then normal way.
              85 325e 2.7 ITB'd stroker
                • 37833
                Well I'm thinking I will try for pulling them together, I have no problem with removing the hood or radiator from the car. We'll see, but I'm glad to know it's not impossible.
                Thanks guys.
                BimmerHeads.com
                • Matto
                  • Jan 2004
                  • 800
                  Thanks guys.
                  Removing the hood and radiator is cake.
                  The A/C condensor shouldn't get in the way.
                  • Super Eta
                    • 1884
                    Is it alright if i ask. Why?
                    I mean why are you taking the engine out of the 325i?
                      • 37833
                      To rebuild it. :roll:
                      BimmerHeads.com
                      • BlackE30
                        • Sep 2004
                        • 605
                        I just put a rebuilt m20b25 in my car. I unbolted the trans from the block which was pretty easy. The hard part was realigning the clutch/flywheel with the trans and getting it to slide into it.
                        • Super Eta
                          • 1884
                          ok...right
                          from my experince of doing it both ways such as unbolting tranny and not, i ahve found pulling the engine with the tranny to be easier.
                          Goodluck either way. :up:
                            • 37833
                            Ya, I'm gonna do them together, gotta do the clutch and all that other shit too anyway.
                            BimmerHeads.com
                            • george graves
                              • 20003
                              Do it together - those tranny bolts are a bitch - hood bolts and radiator support are so easy to remove. Plus you have a lot more room to work with the hood off.
                              Originally posted by Matt-B
