Trailing arms and rear axle carrier questions
  • clutterbucker
    • Jun 2004
    • 481
    So I just ordered new rear subframe mount/bushings (same as rear axle carrier bushings right?) and trailing arm bushings due to a VIOLENT clunking noise when my rear suspension feels a bump or any acceleration. I can't find anything on replacing the subframe mounts in the Bentley manual...they don't really go over it. I was going tohold off ont he trailing arm bushings until later on due to the complexity and tools necessary to replace them. Do I have to remove the trailing arms and thus the brake lines and rear axles in order to replace the rear subframe mounts?
    Anyone know?
    - 2000 Audi S4 Stg 2 (sold)
    - house (bought)
    - 1997 Civic Hatch (shaky but driveable)
    - 2010 Sportster 1200 Forty Eight Ed. (vroom)
    - 1991 318is S50B30 (TBA)
  • Jordan
    • 12916
    Re: Trailing arms and rear axle carrier questions
    Yes. Good luck getting the subframe mounts out without a special tool, or a torch.
    https://mtechniqueabs.com/
    • Digitalwave
      is a poseur
      • 6300
      I did my subframe bushings with a torch and a 6" gear puller from Harbor Freight, and a BFH. It wasn't hard.
      RISING EDGE
      • clutterbucker
        • Jun 2004
        • 481
        Well, I'm not doing it alone, I was just wondering if I should ask my godfather to replace my trailing arm bushings since they'll already be off....sounds like it would be a good idea.
        - house (bought)
          • 34847
          yeah, you'd be saving yourself labor down the road.
          I made a tool for my subframe bushings. my torch was too weak to melt them and I had a welder and scrap metal available.. made easy work of it, only a couple minutes to pop them out and the poly bushings slid right in.
          • clutterbucker
            • Jun 2004
            • 481
            yah....maybe for you. I don't think I'm going to attempt removing all of the necessary parts with just a jack and two stands. it would be a very uncomfortable and long day.
            - house (bought)
            • Digitalwave
              is a poseur
              • 6300
              I did mine alone and 2 jackstands are all you really need.
              RISING EDGE
