2002 Engine Swaps
  • Stu Mc
    • 4083
    believe everything you read robert 8)
    • Werksmini
      • 1658
      The 2002 should of come stock with an S14. But the cost/what you get ratio isnt worth it IMO. Anything you put in there will make it an uber fun car.
      I bombed Korea every night.
      • rwh11385
        lance_entities
        • 18403
        How accurate is the posting on that forum? Your dad had that S14 2002.
        • mti88m3
          • Oct 2004
          • 24
          Originally posted by M-technik-3
          All the above have been done. A built 2.0 M10 or a S14 would be nice. M42 or M44 why not modern engine with good parts backing still available from factory. Sorta like the factory M2.
          Including the S38? Can you point me to any info on this?
          Originally posted by rs4pro3
          Where did he find an S38 for a Grand?
          This completely random guy. I just stumbled into it.
          I'm no longer concerned with it fitting without modification, I'm looking into going with a mid-front engine setup (even out the weight distribution AND allow me to use the S38).
          Does anyone know what my options are for the transmission? I'm new to 2002's, it has the stock 4 speed. Is there any compatibility here?
          Thanks for all the help
          Jon
          • UNHCLL
            • 8790
            you'll have to run the m5/m6 tranny I think.
            major firewall modification will be necessary.
            there is a silver/black 02 owned by a pilot in the mid-west with an S38.
            Below the radar...
            • trent
              There is a long legend behind that car. The S38 was put into the 2002 by Korman, and the car was beautiful. The guy was a test pilot for Lockheed Martin and actually passed away i believe 5-7 years ago. The car has since traded hands numerous times. I have seen it for at about 3 seperate times.
              HTH,
              • rwh11385
                lance_entities
                • 18403
                Don't worry, he is crazy
                "yeah, but we've got a welder to play with now!" - Jon
                Sweet. It's good to know its possible.
                • Digitalwave
                  is a poseur
                  • 6299
                  Anything is possible.
                  RISING EDGE
                  • mti88m3
                    • Oct 2004
                    • 24
                    I thought that might be the case.....
                    Does anyone have any more information about this car? I'll check around, but I have limited resources.
                    That's what I like to hear! I usually go with the double negative "Nothing is Impossible"
                    • george graves
                      • 20003
                      HTH,
                      Use the getrag 265 e30m3 tranny - it's has a removable bellhousing that will make the swap much easier. I used it on my m30 e30 swap and it's helped alot.
                      Originally posted by Matt-B
                      • rs4pro3
                        • 5808
                        A s38 With burnt valves is going to cost a TON to rebuild. Or else I'd be all over a $1000 S38. Any m30 tranny will bolt up but some arn't as strong as others.
                        85 325e 2.7 ITB'd stroker
                        • Alex Mc
                          • 281
                          M42 is by far the best bang for the buck -- Any 6 will upset the balance of the car severely. Pete ran a built M20 before the S14, but that was before there was such a thing as a hot setup for the '02 in terms of swaps outside of an M20 (the 'i' wasn't even out then!)
                          The S14 is the greatest setup, but a lot more money.. you can pick up running M42's for $700 or so, a decent S14 is $3500+
                          We've done roughly 45 or so S14/02s, but the M42 has been the most popular one for the last few years..
                          Call for more info, 336 761 0643, Precision Performance
                          Current: Brilliantrot '91 318is M20B25
                          Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
                          wamchenry@gmail.com
                          insta: @simple_machines
