Hooking up a laptop
  • hella 325
    • Sep 2004
    • 380
    Hooking up a laptop
    I have been looking with no luck. What kind of software and hardware do i need to hook up my laptop to my car. Idealy id like to be able to alter a/f and timing. I dont know if this is possible, id atleast like to be able to diagnose them if not change. (also monitor sensor readings and error codes) Is this possible? If so what do i need and where can i get it? thanks guys
    Russell
    1987 325is
    1992 240sx coupe
    1994 525i
  • bimmerphile
    • 3495
    you need new engine management.
    Try SDS
    • Rob
      • 8166
      theres other ways, but i'm too lazy to look
      BEERTECH
      • hella 325
        • Sep 2004
        • 380
        I couldnt find anything on it, ill look up sds
        EDIT: couldnt find any info on it really
        Russell
        1987 325is
        1992 240sx coupe
        1994 525i
        • Madhatter
          • Oct 2004
          • 966
          Carsoft has provisions for it iirc, the problem is communicating with the ecu, you need to make the controller :(
          Just a little project im working on
          - http://www.lse30.com -
          • hella 325
            • Sep 2004
            • 380
            so there are no "kit" type things?
            Russell
            1987 325is
            1992 240sx coupe
            1994 525i
            • Rob
              • 8166
              i've definitely seen things like this for PDAs and laptops, but they were always expensive $200+, and for more modern cars
              BEERTECH
              • Digitalwave
                is a poseur
                • 6292
                SMT-6 lets you hook up a laptop and use its software to tune the fuel curves. It's about $350 for the basic SMT-6 piggyback kit.
                Question is, why do you need to tune this stuff? What do you have under the hood?
                If you want to read your A/F levels, you should be buying a wideband O2 sensors with a digital readout gauge.
                RISING EDGE
                • hella 325
                  • Sep 2004
                  • 380
                  well, as of yet other than a custom ROM nothing special under the hood. However I do have plans for it. Im looking at gettin a MAP sensor instead of the AFM and i want to be able to hook my laptop up and adjust fule curvs...hmm can ya guess the plans?
                  200-350 expenicve???? Thats CHEAP... The motec system i was looking at was like $6500 lol
                  *hint* Kompressor :twisted:
                  Russell
                  1987 325is
                  1992 240sx coupe
                  1994 525i
