REDLINE MTL VS REDLINE MT - 90
  • e30 gangsta
    • 3877
    what do you guys prefer... or have used... the nomal mtl or the mtl 90????
  • PanamaE30
    • Oct 2004
    • 768
    I always see on Bimmer mag Q&A that they suggest using Redline ATF..
    1988 325iC - "Betty" - Daily Driver/Project Car.
    1993 318i - "The Golden Dream" - Dad's Car.
    1995 318ti - "Hellrot" - R.I.P.
    • e30 gangsta
      • 3877
      yeah but why use it if i live in miami.... isnt atf supposed to be used in cold weather startups???
      • PanamaE30
        • Oct 2004
        • 768
        Well ATF is Automatic Transmission Fluid, but they recommend it for manual transmissions too..
        Something about the mix being good for all transmissions in general. I've yet to try it.. my transmission could use a change...
        • Digitalwave
          is a poseur
          • 6300
          They recommend it mainly for very cold temperments.
          RISING EDGE
          • Den
            • Mar 2004
            • 162
            The issue is also probably clouded by the fact that ATF is BMW spec in certain manual trans. Don't ask me which ones. I think the drain plugs on them have a projecting hex head instead of a recess for an allen wrench.
            MTL vs. MT-90?
            Ask Redline.
            Red Line has a reputation with racers and enthusiasts alike for creating products that perform and protect better than any on the market. No compromises.
            800-624-7958
            • e30 gangsta
              • 3877
              thanks guys ill ask....
