Check Engine Light is Blinking the brake sensor is lit
  • beybedba
    • 517
    what could be wrong with my car if the CEL is blinking?
    also, my brake sensor is lit.
    how can i fix these problems?
  • Alkasquawlik
    • 4557
    You're going to need to be alot more specific. Those questions are WAY too vague. There are any number of things that could set those off.
    And I assume that you mean your brake sensor is lit, not your break sensor.
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      well youre brake pads might be wearing really thin and your sensor is worn through
      • beybedba
        • 517
        oops my bad, hmm while driving the car the CEL is blinking. oh yes i meant "brake" not break
        • daniel
          • 6703
          are you sure its the CEL and not the check panel light in the very center of the gauge cluster?
          http://instagram.com/dslovn.drives
          • beybedba
            • 517
            oopsie... yea it's that light at the very center of the speedometer .. it's blinking " CHECK"
            • wodcutr
              • Apr 2009
              • 2193
              The check light means that you have a problem with something that the check panel is warning you about. If you push the bottom right button it will stop flashing, but the warning light on the panel will still be lit until you fix the problem. The brake lining light could be that you need new pads, but it might also be a bad connection on the sensor or the sensor was never replaced with brake job.
              The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
              • beybedba
                • 517
                you said something about pushing the " bottom right button". what button are u exactly pertaining to?
                  The button on the check panel.
                  • wodcutr
                    • Apr 2009
                    • 2193
                    The check panel is in the overhead console between the two sun visors. It has red lights on it with words next to the lights that say oil level, coolant, washer fluid, etc. Push the button that says "check" and all the red lights will illuminate. The flashing yellow "check" in your dash will quite flashing.
