Oil change light reset
  • cahomey
    • Mar 2004
    • 1201
    Does this sensor reset on its own? I changed my oil today and I was finishing up and couldn't get to my computer to check the pair of pins that needed to be connected.
    But when i sat down and looked up I saw the light had turned off.
    There must be a sensor in the oil filter housing or something. Someone fill me in.
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • ryan_george
    • Mar 2004
    • 331
    I don't think it resets by itself. My oil light has been on for about a year now, with numerous oil changes since then.
    Don't really know what else to tell you!
    • parkerbink
      • Jun 2004
      • 10138
      In the engine compartment there is a black round cap (left of the front of the engine standing on the driver's side) open it, put a wire in pin #19 & #7 Turn the ignition to on (just before starting the car) do not start. The inspection lights will light, when they go off (about 3 seconds) turn the key off. Any longer & you will reset the inspection interval.
      Heres the complete write up:
      • cobraken
        • Oct 2004
        • 674
        SHIT! I just bought the rest tool! damit! oh well
        Randall Racing and Engineering
        Acworth, Georgia, 30101
        http://www.facebook.com/RandallRacingandEngineering
        • cahomey
          • Mar 2004
          • 1201
          ....wow
          Don't tell me you got one from the stealership.
          • cobraken
            • Oct 2004
            • 674
            na i bought one on ebay for around 35 bucks. but still thats 35 bucks, you know.
            • parkerbink
              • Jun 2004
              • 10138
              Mine is a scrap piece of speaker wire.
                • 34844
                just an FYI, early cars have a different diagnostic connector and pins 19 and 7 don't work for the reset, that only applies for later cars. I don't know what pins work for the early ones, you can find that out easily enough if you do some searching..
                • cobraken
                  • Oct 2004
                  • 674
                  If mine is an 86 is it late or early?
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Good point. pins 1 & 7 on early cars,go here:
                    & scroll down. It shows early cars. It doesn't say years but it does say there are 15 pins, so if you have 15 pins you are early.
                    The early type connector:
                    Diagnosis plug connections:
                    No. Terminal Designation 1 31 Ground 2 - - 3 - - 4 FT Temperature gauge 5 L Engin M10B18 Interfrator output for CO adjustment Engin M30B34 Oxygen Sensor signal 6 A Diagnosis lead for SRS 7 SI Service indicator 8 P+ Position sender 9 S Shielding 10 P- Position sender 11 50 Starting pulse for starter 12 61 Alternator charge indicator 13 1 Ignition signal 14 30 battery + 15 15 Power supply for ignition
                    The late type connector:
                    From the BMW NA 1989 Electrical Troubleshooting Manual for the 325i/iS:
                    Pin Wire Size Wire Color Circuit and Component Connected
                    1 1 BK Ignition Coil, Motronic Control Unit
                    6 0.5 WT/BK SRS Connector (Not Used)
                    7 0.5 WT/GN Service Interval Indicator, Service Interval Processor(Reset).
                    11 2.5 BK/YL Starter, Start Signal(50)
                    12 0.75 BU Charge, Alternator(D+)
                    14 2.5 RD Battery
                    15 0.5 WT/YL Motronic Control Unit(RXD)
                    16 1.5 GN/WT Oxygen Sensor
                    18 0.5 GN/BU Motronic Control Unit(Programming Voltage)
                    19 1.5BR BR Ground Distribution(G103)
                    20 0.5 WT/VI Motronic Control Unit(TXD)
                      • 34844
                      early
                      • cobraken
                        • Oct 2004
                        • 674
                        sweet, i have an early e30 :roll:
                          • 34844
                          ask a dumb question, get a dumb answer. :idea:
                          • cobraken
                            • Oct 2004
                            • 674
                            Havent you heard their is no such thing as a dumb question? I really didtnt know.
