how do you disable ABS?
  • bmwannabe
    • 900
    im tired of the shit and i want it gone, educate me.
  • Charlie
    kid tested, administrator approved
    • 6686
    Disconnect the white relay by the driver's side front fender.
    Don't sue me if you break anything or wreck.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
      • 34844
      I hope you never have to stop and turn at the same time, especialy in the rain.
      • Jordan
        • 12916
        https://mtechniqueabs.com/
        • bmwannabe
          • 900
          no i fucking almost lost it the otherday, my brake pedal felt like there were rocks glued to my rotors, and the pads were going over them ( if thats a good description)
          • parkerbink
            • Jun 2004
            • 10138
            I would think the system is made taking every aspect into consideration and removing a part of that system would have unpredictable and undesireable results, but I could be wrong.
            • Charlie
              • 6686
              That's what ABS feels like when it's engaged. It's working normally.
              -Charlie
              FYYFF
              • bmwannabe
                • 900
                i dunno it just felt fucked up.
                • PanamaE30
                  • Oct 2004
                  • 768
                  Learn to drive :D
                  honestly though, the ABS shudder is a lot more pleasant than having your tires lockup and you drifting into a solid object.
                  1988 325iC - "Betty" - Daily Driver/Project Car.
                  1993 318i - "The Golden Dream" - Dad's Car.
                  1995 318ti - "Hellrot" - R.I.P.
                  • Axxe
                    • Aug 2004
                    • 3355
                    Learn to drive :D
                    Keep it slideways!!
                    • jblack
                      • Aug 2004
                      • 98
                      Can you guys hear it....
                      Tick, Tick, Tick, Tick on bmwannabe....
                      I hope you don't hurt yourself in the wreck!
                      Seriously, if you are engaging ABS on the street, and it is not a panic stop in the rain to save Nuns carrying babies across a crosswalk, you need to cool it down significantly! Go to a track and learn how this whole car thing (brakes, engine and suspension) are supposed to work together before you pull a safety feature out of the car. One tenth of one percent of the drivers on this planet can do a better job of threshold braking than ABS can give you.... and a good number of them are on the World Rally Circuit.
                      Just saying this because the next car you aim at could have someone I care about in it!
                      Sorry to sound harsh, but this is scary!
                      • Brian 89 325i
                        • 1450
                        And i pretty sure the ABS pump acts as your proportioning valve so if you remove it i think you need an external one of those.
                        Brian
                        • PanamaE30
                          • Oct 2004
                          • 768
                          Word.
                          Just to give you an example, just yesterday i was getting off the bridge, and there's this change in road surface.. smooth concrete to bumpy asphalt. Well, the jackass in front of me hits the brakes for no reason, and i was a tad too close.. hit the brakes hard, in the rain mind you, and stopped pretty well. Not bad considering i have bald tires :)
                          • Luda30
                            • Oct 2004
                            • 57
                            I had that happen to me the other day. My best guess i put too much pressure on the brake but either way the end result was me sliding into a telephone pole and in a ditch and i had plenty of braking room before and the car still would not stop because ABS had engaged. BTW it was wet ground and slight rainfall with good tires
                            • PanamaE30
                              • Oct 2004
                              • 768
                              Your mistake was stepping on the brakes too hard..
                              i forgot to mention that in my situation i did not apply enough pressure to engage the ABS.
                              What you really need to do is downshift, modulate the throttle to regain control and steer yourself to safety.
                              slight rainfall is the worst. Those were the conditions in which i crashed. The ground is like soap.
