Engine questions...
  • B2ThaZiZza
    • Aug 2004
    • 614
    Engine questions...
    Hey what is the difference between a e36 318is engine and an e30 318is engine?
  • Il Duce
    Non-Mod M42 Modder
    • 5046
    nothing, until 1995
    http://www.bimmerparts.net/bmwpart/m...gn_codes.shtml
    correct me if i am wrong though...
    • B2ThaZiZza
      • Aug 2004
      • 614
      ok check this out...http://www.kormanfastbmw.com/turbos.htm[/url]
      • Rob
        • 8166
        the e36 motors have different intake manifolds and knock sensors
        BEERTECH
        • B2ThaZiZza
          • Aug 2004
          • 614
          check out the site is it possible to be used on an e30?
          • Jordan
            • 12916
            No.
            https://mtechniqueabs.com/
            • B2ThaZiZza
              • Aug 2004
              • 614
              Fuckit then, im about to buy this m44 engine that my mechanic has, only thing is that it doesnt have a tranny. Will my stock 318is tranny work (it has a brand new clutch) and a 4.10 LSD. Will i beable to use my jim conforti chip that is on my stock engine still? what else do i need to get while it will be at the shop.
              • jblack
                • Aug 2004
                • 98
                The M44 is an OBD2 engine - the M42 is OBD1. You will have a lot of issues getting the engine to work on a car that never saw OBD2. You can make it work with stand alone electronics, but it is not worth the pain or money.
                  • 34847
                  Originally posted by IL DUCE
                  nothing, until 1995
                  bzzt.. the E36 motors have knock sensors, the E30 motors do not. they are not exactly the same.
                  • B2ThaZiZza
                    • Aug 2004
                    • 614
                    scratch the last post nvm. the engine is a 1.8L Z3 Motor from a 95 z3. My mechanic did a swap from the 1.8L to the m3 motor so he is selling the motor as is for $2700. There was a typo on my mechanics ad for the motor. But regard my questions about my tranny,lsd, and chip.
                    • Digitalwave
                      is a poseur
                      • 6300
                      You are retarded if you spent almost $3,000 on another 4 cylinder and it wasn't an S14.
                      RISING EDGE
                      • B2ThaZiZza
                        • Aug 2004
                        • 614
                        where the hell can i get one of those arent they hard to find!?! Find one for me and ill buy it then ive almost 7 grand i can spend. and i need one from a 1991 e30 m3 cuz my car is a 1991
                        • Brew
                          • 3060
                          S50?
                          '91 318is
                            • 34847
                            $7k? why are you even looking at stock E30 motors?
                            • grapedrink
                              • 1514
                              :stupid:
                              Put the 4.4L V8 in if you have that much for a motor swap. Chances are that he doesn't have the money :roll:
                              Originally posted by DaveCN
                              Welcome.
                              Your car is a piece of shit.
                              Most of them here are, too.
