i thinks its a pretty good idea josh.... i just wish i knew where to pick up a CAI
CAI hood vent?
The "scoop" I put in my hood was for shits and giggles I already had another hood lined up... So I was having fun with the hood I had. Look how much bondo was on that hood... you think I had any intention of keeping it?
Josh has become another riceboy dreamer.Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/Comment
http://e30m3performance.com/installs...ent/index.htm\
credits to gustave stroes
this is the main and only reason any car should/need a hood scoop unless your force feed or a muslce car, cause well you know they rule.
as for you idea josh, i like the benz, or howabout something csl style or maybe routing air up from the brake ducts? something like bmpd did on the e36's (i don't like that company btw)
-camComment
Ok, I just read ur suggestion. The funny thing is I've been thinking about this, for a while as well. I've been under my car, and looked. u can run some piping from the brake vent to the airbox, so long as u remove that plastic piece, that pushes the air to the brakes, or in my case I'm getting a modified one made up so that I can use the air, for the breaks and the airbox. I've been thining seeing as we got the metal airbox here in South Africa. I'm getting the idea of using BMC Caron Dynamics Airfilter, the best of both worlds, cone, and airbox in one. Then I was also thinking that using the stock airbox with a cut out in the bottom, and the pipe going into tht using a quality flat panel filter would work better. cause the air woulb be going straight onto the filter. I just need to organise another airbox, and the it will be a for away. Some ppl, have been telling me that u shouldn't be putting it that low to the road, but I've been looking at a lot of our track cars here, and most of them do it that way, Damn even our turbo E30's put the cone in front of the right front wheel. Another thing on the Bonnet, the vent is done by many of the guys that race their beemers here in South Africa, but it is done on both sides, and also mainly to let heat out the engine bay, but it does work, cause the filter is still recieving colder air than it would without the ventOriginally posted by 1985bmw325ei think the hood vent idea is not that bad. If you can pull it off, i congratulate you. However, if it's going to be used for daily driving, i dont know what you're going to do about rain getting in it!
Is there a possibility to connect a tube to the brake ducts that would feed air to the intake?
First of all....
The myth of RAM AIR is exactly that. A myth. Someone did the calculations... The super cool headlight delete mod would only provide like .1bar positive pressure at something like 120mph. Same with a brake duct vent.
topical help:
http://www.cardomain.com/memberpage/657919.
Below the radar...Comment
It wasn't even .1 bar, it was like a .2-.4 HP increase at a 100mph or something like that.Originally posted by UNHCLLFirst of all....
The myth of RAM AIR is exactly that. A myth. Someone did the calculations... The super cool headlight delete mod would only provide like .1bar positive pressure at something like 120mph. Same with a brake duct vent.Comment
Lol, that M3 chris posted:
"Features:
- Lightweight perimeter protection
- Multi-layered ballistic glass
- Operable front windows
- Computer armor
- Protected battery
Optional Security Modifications:
- Underbody grenade protection
- Locking fuel cap
- Protected fuel tank
- Inside/outside intercom
Luxury upgrades
- Public address system and siren
- Run-Flat tires"
its armored, LOLBEERTECH
maybe its 50 cent's?Originally posted by RobLol, that M3 chris posted:
"Features:
- Computer armor
- Protected battery
- Locking fuel cap
Luxury upgrades
- Run-Flat tires"
its armored, LOL
been hit wit a few slugs but i don't walk wit a limp (i'm aiight)I retired my E30 for now...
E46 323i
David SchultzComment
Myth or not, that looks fucking awesome!Originally posted by UNHCLLFirst of all....
topical help:
