S38 [Big 6] conversion??? Whats the "list"???
  • wastedincome
    • Aug 2004
    • 906
    Whois is aware on the ont S38 conversion and what is "RALLY" needed for this swap???
    Please dont give the ol' "Search" respones :roll:
    I am really set on doin this swap overa S52 conversion so I "need" to know whatparts I need to scout out ;)
    Other then engine and related parts what Should I keep in mind on upgrading to as faras suspension and drive train??
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
  • M-technik-3
    • 18946
    Summed up in two words............... MO MONEY
    • rs4pro3
      • 5808
      Everything, basicaly the M30 and the S38 swap is the same. You'll need tranny, engine, mounts, driveshaft, oilpan, and lots more. I'd say unless you had a line on a cheap S38 it wouldn't be worth it.
      85 325e 2.7 ITB'd stroker
      • M-technik-3
        • 18946
        No such animal. Good luck though. What happened by the way with the old M30 Alpina engine?
        • rs4pro3
          • 5808
          Ya, I never see just an S38 for sale by itself without a car attached.
          • wastedincome
            • Aug 2004
            • 906
            just need to hunt........S38 motorsAREout there ;)
            dat Alpinia motorjust didnt seem right....the S38 is what I been wanting and will proppbly wait till I find it
            CURRENT STOCK LIST:
            • bimmerphile
              • 3495
              that should be a start at least
              • Jand3rson
                • 37587
                The S38 is such a badass motor. I love the looks of them, and the power even more.
                • DSchultz325e
                  • Aug 2004
                  • 1158
                  hey it's a hemi
                  I retired my E30 for now...
                  E46 323i
                  David Schultz
                  • oskard
                    • 58
                    The difference on a s38 and a m30 swap as far as I know is that you can't use
                    the stock brake booster, you will have to go hydrolic or ix/e21 booster.
                    You also have to beat up your firewall to make room for the exhaust manifold.
                    You will need motormounts, there are three places on the engine you can attach
                    motormounts. if you use mounting thing nr 3 the engine will be very close to the
                    firewall but you will be able to use a normal radiator and the cooling fan on the engine.
                    in mounting thing 2 you will not have space for a engine fan but i belive you can use
                    a normal radiator in nr 1 you will not have space for engine fan and you will need
                    a very thin radiator like the ones alpina used in their conversion.
                    Alpina only made mounts for mounting place 1 and 2 but you can either make mounts
                    your self for the 3rd place or buy them from www.e30.de
                    You will need to make a custom driveshaft, shorten the shift rods and a custom exhaust.
                    • trent
                      I have blocks, heads, camtowers, etc... to build an S38 (either 3.6 or 3.8) Won't be cheap though.
                      And I will not sell individual parts. Only an entire engine built.
                      • wastedincome
                        • Aug 2004
                        • 906
                        Nice tips and good write up thanks
                        CURRENT STOCK LIST:
                        • wastedincome
                          • Aug 2004
                          • 906
                          So now I'm curious as to what your lookin to get $$ wise ;)
                          CURRENT STOCK LIST:
                          • wastedincome
                            • Aug 2004
                            • 906
                            Another thing.......What about rear end's???? I cant emagine a stock 325is rear end would hold up long :roll:
                            CURRENT STOCK LIST:
                            • kylebes1
                              • May 2004
                              • 2804
                              For the engine you have a couple options:
                              Buy a messed up M6, US version is ok but if you can find a gray market one with a Euro m88 you will be happier with power but cost and parts rise quickly.
                              I say get the M6 because you can use the transmssion as well I think.
                              you will need a custom lenght DS and completely custom shifter.
                              I think the best varient of the s38 will be from an e34, if you can find one. It has better engine management and will alreday have the oil pan you need.
                              cooling is always an issue, my friend has a m30 in his e30 and he has to run a electric fan in front of the radiator (no space on the other side) to keep it cool in the summer, even with a lower temp thermostat, but he freezes in the winter, we are workign on this lil probelm though.
                              You wil need either Alpina B6 engine brackets, or the ones from http://www.e30.de/
                              The list is long.....
