brake lining light on???
    my brake lining light is on in my 89 325i and i dont have an onwers manual..what does it mean?
    nice...
    E30 325ic - Project
    F30 328i - Daily
    E38 740i Sport - SOLD
    E92 335xi - SOLD
    E60 525xi - SOLD
    E46 330ci - SOLD
    E30 325ic - SOLD
    E30 318is - SOLD
      It probably means that it is time for new pads and rotors.
        I always get new sensors (2) whenever I change the pads.
          or just ground the two wires together
          1989 cirrisblau-metallic 325i
            Why would you do that?
            The sensors are cheap, might as well replace them when you have the brakes apart.
            Project
            Feedback
              I took out the light. I keep check on my brakes as it is. Plus, It's free. :up:
              -tim
              Originally posted by Jordan
              I like the stance
                dude, it means its time to get a manual
                but for real
                your pads need to be replace or you have a loose connection between harness and sensor
                Originally posted by Lof8
                4 doors allow you to transport more whores.
                therefore, their value is much greater.
                Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
                  why hell yeah... thats what I do
                  sigpic 1987 325is
                    lets not give him the easy way out this early, jeeze
                      do an inspection of all brake pads look for uneven where or low worn out pads
                      then check your brake pad sensor
                      :borg:
                        and rotors...
                        then while your in there do tms drilled rotors on all corner, hp plus pads, ss lines and get a manual
                          My brake lining light is on too, so I know I need atleast pads.
                          Do I need to get new rotors? I'd rather not buy something if it's not something totally necessary. How do I check them to make sure they are ok?
                          SC*AR
                          Originally posted by JamesE30
                          And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
                            The rotors need to be replaced when they are worn close to or below the wear limit documented in the Bentley or TIS. Allowable wear is 2mm, or one 1mm per side. A simple check is to compare the ridge at the edge of the rotor with the thickness of a worn dime, which is close to 1mm.
                              +1, It is suppose to mean the brake pads are worn down and needs inspection and or replacement. Check the pad thickness, inspect the pad sensor wire for wear through, measure the disc thickess with a micrometer and compare the measurements against the service manual allowable spec limit. Sometimes the rotors can be turned/machined to straighten and reused. The sensor wire circuits are also known to have a bad connection (open circuit) leading to the service light turning on periodically.
                              sigpic.
