M30 so close to starting but won't
  • rs4pro3
    • 5808
    Just tried cranking the m30 after fixing some few small problems(bad main relay and reference sensor).
    It cranks and you can hear the engine struggling to try to run, but it won't if you pump the gas it fires a little easier but won't catch.
    Any ideas? I'm thinking maybe fuel pressure or the ICV. I ran a resistance test on the icv and it work but I haven't tried suppling power to it to see if it closes or not.
    85 325e 2.7 ITB'd stroker
  • Jon325i
    • 6934
    I would look into the fuel pressure.....sounds like its not getting enough/any. Have you tried prying open the intake boot at the throttle body and give it a shot of gas just to see if it will run? I tried this techique once years ago when my Porsche 924 wasn't turning over. The shot of gas worked.....turned out to be the mechanical fuel distributor stopped working.
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • rs4pro3
      • 5808
      It's getting fuel, as I pulled the return line to make sure I had them hooked up correct. I'll test the pressure tommorow.
      • Madhatter
        • Oct 2004
        • 966
        Do you guys have this stuff called aero-start in a spray can. Basically you can spray it into an intake to get an engine to start. It is basically just a pressurised alcohol spray in a can, good for little things like this.
        Just a little project im working on
        - http://www.lse30.com -
        • rs4pro3
          • 5808
          I don't know, I made a fuel pressure guage, and will test the pressure tommorow.
          • E30/M30
            • 224
            Is it sparking ok ?
            Any sign's of fuel on the spark plug's ?
            Hope you get it sorted soon mate.
            Andy
            • rs4pro3
              • 5808
              It's got spark, I tested the fuel pressure today and it has 38psi but there is a leak by the #2 injector.
              • george graves
                • 19998
                Sounds like a reference sensor is still tripping you up.
                Originally posted by Matt-B
                • rs4pro3
                  • 5808
                  Ya It may be the Speed sensor, I'll steal that one from our 528e maybe, but first I have to fix this fuel leak as it may be the cuase.
