Which oil filter to get?
  • themitchster359
    • 654
    i use fram, castol 20w50, works fine to me...i didn't know that there was much of a difference.
    89 Alpine White e30 325i
    • SpecM
      • Oct 2005
      • 4531
      the Mobile One filter are made by Purolator btw... and there is no PureOne filter that fits m20s, just the standard "premuim"
      btw I use Mobile1
      1989 cirrisblau-metallic 325i
      • z31maniac
        • 17566
        I'm confused. It sounds like you started this thread to validate your own opinion rather than listen to others experience on the topic.
        www.gutenparts.com
        • Quailane
          • 131
          No, I was curious between the Mobile 1 and Purolator PureOne. All I got was people telling me to get the OEM. I'm still not sure I made the right choice, between the two, but at least I know they are better than the OE filters.
          btw I use Mobile1
          There might be none that is the OE size, but they make plenty of filters that physically fit on the M20. The Mobile 1, K&N, and Royal Purple filters are all identical and are very distinct from any of the Purolator filters. They are for sure not made by the same people.
          Here: http://minimopar.knizefamily.net/oilfilters/index.html
          He says the Mobil 1 is made by Champion Labs and it looks like the one I got. The Purolator filters are all very light in comparison to the Mobil 1's. I spent a lot of time looking at oil filters during several trips to pepboys and bought several over the past week.
          • Liam
            • 753
            No matter who is selling the bill of goods... There is no better filter than the OEM.
            And just because the filter fits physically doesn't mean it will work right... Or work at all.
            I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
            • Quailane
              • 131
              And why not?
              Oh please, where do you come up with this?
              • netcsk
                • Apr 2004
                • 1609
                I also use Mobil 1. Through the reading I've done, it has come up as the best. Mann and Mahle have come up pretty good as well.
                • 330SMG
                  • Feb 2007
                  • 172
                  I use The Bosch for the simple fact they are easy to get and they are very well made. Anything Fram is JUNK. Here is a very in depth study of oil filters.
                  1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
                  • Liam
                    • 753
                    Originally posted by Quailane
                    And why not?
                    Where do I come up with this?
                    I've been a BMW tech since the e30 was new.
                    Case in point
                    Some filters run from the nipple out and some from the ring in... If the bypass valve is backwards for your app the filter will just bypass the oil straight back to the engine unfiltered.
                    fucking idiot
                    • Quailane
                      • 131
                      Case in point
                      fucking idiot
                      Ok numbnuts, let's assume I already made sure of this. So how come no filter can be better than OEM?
                        • 34844
                        I don't know if they've changed the design, but about 10 years ago Fram filters were made with cheesy paper internal casings glued to the filter elements and thin flimsy bypass valves. the glue that held the internals of the filter would come apart, the filter element would disitegrate and bits of paper/cardboard would get sucked into your oil passages.
                        in a pinch I'd get a Gold filter from Napa, otherwise I order OE filters 5 at a time.
                        • Liam
                          • 753
                          They could be... They just aren't.
                          The Mahle OC49 is the ONE filter that is specifically designed (Correct bypass opperation and ADBV funtion) for the BMW M20.
                          And the filtering media is top quality.
                          And I assume nothing about thread monkeys...
